battery drain
  1. K1525682912409
    Cupcake Jun 7, 2019
    L1545816154510 likes this.
  2. Sai Krishna Thorata
    Ice Cream Sandwich Jun 7, 2019
    Sai Krishna Thorata , Jun 7, 2019 :
    check which app is consuming more battery or which is running in background. force close that app.. and better uninstall that if wont use it much
  3. whe1954
    Gingerbread Jun 7, 2019
    Jacek Pecka and borft like this.
  4. borft
    Jelly Bean Jun 7, 2019
  5. artloverjv
    artloverjv , Jun 7, 2019 :
    Totally works. The trick, however, is to use the phone as headrest.
    buntycubal and borft like this.
  6. izaan24
    Cupcake Jun 7, 2019
  7. Waveform Modifier
    Marshmallow Jun 7, 2019
    Waveform Modifier , Jun 7, 2019 :
    What is correct? What are you even talking about? You should stay on topic. Your post made no sense.
  8. Waveform Modifier
    You should review the pinned battery thread. Also, you should leave your phone plugged in over night to let the OS time to optimize battery usage, as optimization requires a quite a bit power to run.
    Please use the forum and its resources before you creating a thread as this had been addressed many multitude of times before.
  9. izaan24
    Cupcake Jun 12, 2019
    izaan24 , Jun 12, 2019 :
    I mean that check which app is consuming battery or do 1 thing u go to settings and go to advance option and to recent and set from normal clear to deep clear
    It will force stop all the apps and u will get longer battery life
