3
[Submitted] Battery drain
  1. Y1540976550600
    Donut Aug 15, 2019
    Y1540976550600 , Aug 15, 2019 :
    Battery getting drain below 40%
  2. Hansikanc
    Cupcake Aug 21, 2019
    Y1540976550600 likes this.
  3. brelak
    Donut Aug 27, 2019
    brelak , Aug 27, 2019 :
    Mine too. I have a 3T. This latest update has drastically changed something.
  4. Hansikanc
    Cupcake Aug 27, 2019
    brelak and Y1540976550600 like this.
  5. N1540149598332
    Cupcake Aug 30, 2019
    N1540149598332 , Aug 30, 2019 :
    I think its the new update that drains battery so fast i have OP6 |--> A6003_22_190801 <--|
    But i heard about that android 10 for oneplus its going to be released soon it has cool new things and hopefully the battery drain will be fixed on that.
  6. Y1540976550600
    Donut Sep 9, 2019
  7. M1551282317396
    Cupcake Sep 16, 2019
    M1551282317396 , Sep 16, 2019 :
    do you have android 10?
  8. N1540149598332
    N1540149598332 , Sep 16, 2019 :
    no i don't i go everyday manually check if the update has came but till this day its a no...
    M1551282317396 likes this.
  9. M1551282317396
    how long does the battery last? and usage time? thanks
  10. N1540149598332
    well i haven't counted but i use power saving mode all the way from 100% and i listen to music and only snap and like it lasts like that about 2 to 4 hours its terrible...
  11. M1551282317396
    ok hopefully good
  12. N1540149598332
    Cupcake Sep 19, 2019
    N1540149598332 , Sep 19, 2019 :
    no, i have android 9 but the new update on android 9
