Battery Drain
  1. L1531651924173
    Cupcake Jan 11, 2020
    L1531651924173 , Jan 11, 2020 :
    Hi After the latest update 10.0.3 Battery drain is drastic, without playing games or no heavy usage.
    I charge my phone 100% within 2 hrs it comes down to 75%
  2. MVidall
    MVidall , Jan 11, 2020 :
    I'm having the same problem after the update. Is there any solution for this battery drain problem?
  3. G_Ammar_Khan_DnbE
    Cupcake Jan 14, 2020 at 8:17 PM
  4. Caomhin
    Jelly Bean Jan 14, 2020 at 9:04 PM
    Caomhin , via OnePlus 6T , Jan 14, 2020 at 9:04 PM :
    Just in case there is an App hogging resources, causing lag, Battery drain or freezing, clear your recent apps, also try setting 3rd party apps to Optimize in Settings Battery, only leave the ones you need run in the background or to notify you such as messages, email, Google Services, oneplus etc on Intelligent control.
    Also charge your phone to full and restart it after optimizing, and see if that helps.
    Check App battery stats at about 50% and see if there are particular apps using more battery than necessary.
    How to calibrate your Battery
    https://forums.oneplus.com/threads/...ting-tips-how-to-improve-battery-life.556988/
