Battery Drain via OnePlus 7 Pro
  1. GurkiratKairon
    Cupcake Jul 1, 2020
    GurkiratKairon , via OnePlus 7 Pro , Jul 1, 2020 :
    Battery is draining too rapidly. I have bought ONE PLUS 7 PRO on 12 June.
    Am facing battery drain problem from some days.
    Haven't installed too much apps and also not playing any game.
    Pls suggest if there is any solution.
  2. Liehjan
    Lollipop Jul 1, 2020
    Liehjan , Jul 1, 2020 :
    Start fresh, do a factory reset :)
    Artemus. and Batman360 like this.
  3. GurkiratKairon
    Cupcake Jul 1, 2020
  4. Liehjan
    Not updates, but your apps and data will be erased... So backup everything that you don't want to loose
  5. GurkiratKairon
    Cupcake Jul 1, 2020
