battery drain
  1. M1533395535573
    Cupcake Aug 18, 2020
  2. Praty_28
    KitKat Aug 18, 2020
  3. M1533395535573
  4. Caomhin
    OnePlus 9 Series Expert Community Expert Aug 19, 2020
    Caomhin , via OnePlus 6T , Aug 19, 2020 :
    Try to Optimize the phone, clear your recent apps, also set 3rd party apps to Optimize in Settings Battery, only leave the ones you need run in the background or to notify you such as messages, email, Google Services, oneplus etc on Intelligent control.
    Guide to lower Batter Drain.
    M1533395535573 likes this.
  5. M1533395535573
    Cupcake Aug 19, 2020
    Caomhin likes this.
  6. Dante69
    Froyo Aug 19, 2020
