battery drain
  1. B1528111784536
    Eclair Feb 25, 2021
    AZGARDS likes this.
  2. McJader
    Lollipop Feb 25, 2021
    McJader , Feb 25, 2021 :
    Share some graphs?
    Also you can turn on battery saver, use dark mode, and lower your brightness, optimise the battery usage for apps that use battery a lot
    rhyd1am and Caomhin like this.
  3. hiimanshh_
    Froyo Feb 25, 2021
    hiimanshh_ , via OnePlus 6T , Feb 25, 2021 :
    Try this.....
    Turn off device
    Get into recovery mode ( press volume down + power key together ... until screen turns on )
    Enter your password
    Navigate and select wipe cache ( pay attention dont wipe data )
    After wiping cache .....Reboot your device .
    This trick resolves many problems ...give it a try 👍🏻👍🏻
    #NeverSettle
  4. KluGe
    KluGe , Feb 25, 2021 :
    Please do not create redundant threads to already discussed topics.
    Use search to find solutions for your problem.
    And "so pls handle this issue any software update"
    will not lead to what you wish because this here is a user forum!
    If you want to address OnePlus then you have to report it to them.
    Caomhin and McJader like this.
