Battery drainage in standby
  1. Alvato
    Froyo Sep 16, 2020
    Alvato , Sep 16, 2020 :
    My battery is draining very quick since the last week or so. I'm getting about 2 hours of Screen On Time on an entire day. Today, I tested how much battery is draining in a night and here are the results, 15% without doing anything with the device. It's not a launcher issue because it's the first day I'm using it and the issue comes from before. Thanks a lot for your help
    shinosky31 likes this.
  2. domestoboto
    Gingerbread Sep 16, 2020
    domestoboto , via OnePlus 5T , Sep 16, 2020 :
    Why's the Hyperion launcher high up in the list?
    I gave up on that launcher specifically because of unresolved draining issues. I even had it with Nova Launcher in some instances!
    Your best option at this point is either with the Stock OP Launcher or Lawnchair...
  3. MMoo7
    Eclair Sep 16, 2020
  4. Alvato
    Froyo Sep 16, 2020
    I had the same issue before installing the launcher. Before I was with the Stock Launcher from OnePlus. I already have deleted that shirt launcher.
    Any suggestion on why the drainage is enormous?
  5. saad1957
    Jelly Bean Sep 17, 2020
    saad1957 , via OnePlus 7T Pro , Sep 17, 2020 :
    check apps one by one , in optimization list , you have one or more running in the background, and set it to optimized
  6. saad1957
  7. Alvato
    Froyo Sep 17, 2020
    Alvato , Sep 17, 2020 :
    the icon means it's in saving battery mode. I checked what was the thing that consumed more battery and it was android system
