Battery drainage
  1. PurushothamGowda
    Cupcake Dec 9, 2019
    PurushothamGowda , Dec 9, 2019 :
    Data , wifi , location off and all background apps cleared but still 10% battery drain in one night in OnePlus 7T
    Sleep stand by optimization is also turned on
    Any solutions to prevent battery drainage during sleep ?
  2. G_Vivek_Saraiya_dkFx , via OnePlus 7T , Dec 9, 2019 :
    Do check full device usage once. I do not face battery drainage on standby though but yes on usage the battery performance is really really poor. Though Warp charge makes for it but forget your charger on a day-2day trip and you're dead.
    A1569848749295 likes this.
  3. bprrkl
    Gingerbread Dec 9, 2019
  4. zerog69 , via OnePlus Community App , Dec 9, 2019 :
    Most of the time it is the screen that eats battery, try first turning off the auto brightness under display and keeping the screen slider middle brightness or lower manually. Also can turn off 90hz but seems a little obsessive.
  5. #5
