Battery/Charging battery draining after new update
  1. biplabloveu
    Ice Cream Sandwich Oct 24, 2017
    biplabloveu , Oct 24, 2017 :
    buy a battery insted of phone. you'll get a very huge one at the price of OP5. no software updates needed. nothing.
    Just enjoy the backup.
    Hell yeah!.
    #61
    Killing Intent likes this.
  2. F_Vasu_Shobhit_lBPj
    Gingerbread Oct 24, 2017
    #62
    patricktep likes this.
  3. dinesh7k7
    Eclair Oct 25, 2017
    dinesh7k7 , Oct 25, 2017 :
    Hi friends
    My OP5 mobile battery is draining very fastly. I had full charged my mobile to 100 percent within 1 hour 20 minutes my mobile battery percent was decreased to 94 percent. Before bed I checked my battery percent its 84 percent and when I woke up to check my mobile percent is 60 percent. Note mobile was in battery saving mode. This problem is after update my new patch update 4.5.13
    #63
    H1508026755710 likes this.
  4. TheAnonymousOne
    Froyo Oct 25, 2017
    TheAnonymousOne , Oct 25, 2017 :
    Yes it's a known issue about version 4.5.13, and apparently it doesn't seem to affect all the OnePlus 5 devices since mine isn't experiencing such a drastic drain in battery life.
    There are enough threads on this topic in the community already. Do yourself a favor and use the search function to look for older threads related to this issue and you will easily find your solutions there.
    #64
  5. vk1213
    Cupcake Oct 25, 2017
    #65
    lostLambda likes this.
  6. internity
    Froyo Oct 25, 2017
    internity , Oct 25, 2017 :
    mine is working fine but it seems that volte and always on wifi are the reason for that drain in ur case
    #66
  7. sagarmanas
    Honeycomb Oct 25, 2017
    #67
    M1508899353087 likes this.
  8. Geeky
    Froyo Oct 25, 2017
    #68
  9. M1508899353087
    #69
  10. G_Arup_Sinha_QnjT
    Eclair Oct 25, 2017
  11. Manas_Mishra_1989
    Ice Cream Sandwich Oct 25, 2017
    Manas_Mishra_1989 , Oct 25, 2017 :
    That's right. ai downgraded as well and i get much better SOT now.
    However, for some reason while using WiFi the battery still drains a lot in idle as on 4.5.13 but on 4G network the drain is minimal.
    #71
  12. garudflt
    Donut Oct 25, 2017
    #72
  13. Ramani Mehul
    Donut Oct 25, 2017
    #73
  14. F_Roșan_Bogdan_Radu_XqE
    #74
  15. G_Ashwinder_Singh_akca
    #75
  16. kaviarasan96
    Donut Oct 25, 2017
    #76
  17. Prinas X.
    Prinas X. , Oct 25, 2017 :
    Hi all,
    Sorry to hear that.
    For whom encounters battery drain issue, please kindly help collect log so that we can look into it.
    Here’s the procedure:
    1. Input *#800# in dial-up interface
    2. Tap “oneplus Logkit”, delete history log
    3. Tap "advanced" > "save log type" > enable all options, then click OK
    4. Go back, click "save log", when it informs you whether to reboot, click “cancel”
    5. Go to settings-battery, and take a screenshot of the battery consuming situation
    6. Enter oneplus Logkit, choose “other log info”, click “get top info”, “battery history” several times (with a time gap) and “get bugreport info” just before you finish the log process(it takes several minutes, wait till it’s done)
    7. After that, enter “oneplus Logkit”, tap “save log” again to stop it.
    8. Enter file manager>internal storage>oem log, find the folder, zip it and send it to us along with the screenshot. You can transfer the logs to google and share us a link.
    If battery drains most under normal use, please capture the log when you use normally. If it drains under long time standby, please start it before you go to sleep and finish when you wake up. It’s better to do it when battery is below 50%.
    Note:
    Please send email to:bughunters@oneplus.net with detailed description about the issue.
    Looking forward to hearing from you soon.
    Best regards,
    OnePlus Bug Hunters
    #77
  18. W1508849424074
    #78
  19. G_Arup_Sinha_QnjT
    Eclair Oct 25, 2017
    G_Arup_Sinha_QnjT , Oct 25, 2017 :
    My devices battery is draining without any use after full charge. This is after I have updated latest oxygen os. Any one else having same problem please do let me know.
    #79
    ran basson and mohanaprakaash6 like this.
  20. mohanaprakaash6
    #80
