battery draining and CPU overheating!! HELP
  1. deepu1291
    Donut Mar 18, 2015
    deepu1291 , Mar 18, 2015 :
    Its been about three months since i be taken the phone and already its battery is dying and the CPU gets heated up very often!! I don't use my phone a lot to think that its just overuse. The first week or two my battery was amazing and then it started draining really fast! I remove my charging and after an hour of not using it at all its showing 89%!!
  2. darkclouds
    Gingerbread Mar 18, 2015
    darkclouds , Mar 18, 2015 :
    To eliminate possibility of any of your apps creating this situation, do a factory reset and use it without any user apps. See if the issue is persisting.
    Are you on CM11S, if so which build ?
  3. deepu1291
    Donut Mar 18, 2015
  4. deepu1291
    Donut Mar 18, 2015
  5. deepu1291
    Donut Mar 18, 2015
  6. Gamm86
    Jelly Bean Mar 18, 2015
    Gamm86 , Mar 18, 2015 :
    Settings => About phone.
