BATTERY DRAINING FAST AFTER RECENT UPDATE
  1. mykanwal
    Cupcake Jul 3, 2018
    mykanwal , Jul 3, 2018 :
    Hi. The battery backup has significantly reduced after the recent OTA update in 5T. Please look in the issue.
    G_Stavya_Bhatia_BnTC likes this.
  2. Catalin_Buzescu
    Jelly Bean Jul 3, 2018
    borft and mykanwal like this.
  3. alimonu2011
    Eclair Jul 3, 2018
  4. MentalDraco
    Marshmallow Jul 3, 2018
    MentalDraco , Jul 3, 2018 :
    No it's the same
  5. gazz1701
    gazz1701 , Jul 3, 2018 :
    Just users here - you are not talking direct to OnePlus support...
    If you think issue with battery after update then use this:
    https://forums.oneplus.com/feedback
    Also search through the thread for that update, may be others have same issue and did something to fix.
    Search other threads for battery issues, again others may have fixed by clearing caches or resetting etc.
  6. G_jonny_cool_nxOr
    G_jonny_cool_nxOr , Jul 3, 2018 :
    I did one thing and it worked .. Use your battery to 0% untill it gets shut down automatically and charge it up to 100% ... than clear system cache from recovery and it will work
  7. mykanwal
    Cupcake Jul 3, 2018
    how to do recovery
  8. Atit_Shah
    Cupcake Jul 4, 2018
    Atit_Shah , Jul 4, 2018 :
    Facing battery draining issue since last 2-3 days. 100% fully charged battery drained to 30% in just 5hrs without any heavy usage.
  9. Disha Shah
    Cupcake Jul 4, 2018
  10. kermex
    Honeycomb Jul 4, 2018
    kermex , Jul 4, 2018 :
    Mod, please close this. There are just a few hours since the update is pushed and they already complains about the battery!
