Battery draining fast
  1. Hansu Vivek
    Cupcake Jan 17, 2018
    Hansu Vivek , Jan 17, 2018 :
    It was very dissappointing to see feed back from OP2.. Battery is draining faster past one week.. When contacted customer service got feed back of network issue.. Failed to understand after good 2 yrs how network issue arose. When further followed then got response for buy back at less than Rs 5000. And could be redeemed to buy OP5.
    Why l will buy out dated OP5 for just cost of battery replacement. OP is not providing battery. Company has come to mode of selling targets and not customer services after sales.
  2. rahmannek
    Honeycomb Jan 17, 2018
    rahmannek , Jan 17, 2018 :
    we are all facing the same issue
    its on of main bug in3.6.1
    better to ask Update..
  3. sir_adh
    Ice Cream Sandwich Jan 17, 2018
    sir_adh , Jan 17, 2018 :
    Asking isn't going to do anything. They will say "we'll take note of it" and then toss it into the trash can.
    Install custom ROM or find a new device.
  4. G_sahil_kudalkar_ZUgP
  5. G_sahil_kudalkar_ZUgP
    G_sahil_kudalkar_ZUgP , Jan 17, 2018 :
    the battery was working fine till last week but all of a sudden it's draining so fast that there's nothing that can be done..from 100% till 15 in two hours if used heavily if not within 6 hours it will switch off .. can't afford a new phone at the moment
  6. Rusty NZ
    Marshmallow Jan 17, 2018
    Rusty NZ , Jan 17, 2018 :
    If the battery is two years old it will have degraded significantly.
    If a service centre won't change the battery, you can buy aftermarket batteries from Ali Express and eBay.
    There are guides on you tube that show it is very easy to change your battery. I changed my battery with a battery from Ali Express 10 months ago
