battery draining faster
  1. Rudra_binith
    Donut Jun 22, 2018
    Rudra_binith , Jun 22, 2018 :
    After update to Os 5.1.3 version , battery is draining faster. Is this a global issue or only am facing it ?? - one plus 5 user
    VIKAS_RAIZADA likes this.
  2. rits17
    Gingerbread Jun 22, 2018
    rits17 , Jun 22, 2018 :
    No bro, its not the case, i personally believe that one plus 5T battery back up has slightly increased a bit. if you have recently updated to oxygen OS 5.1.3, then wait for 1 or 2 complete charging cycles of the battery, then you can note the differences.. i am giving u few screenshot where u can see that i have got Screen on time in between 6
    hrs to 7 hrs, and in some cases i got Screen on time close to 7 hrs.
    M1514357664715 likes this.
  3. Jesús Ramírez
    Cupcake Jun 23, 2018
  4. sv2410
    sv2410 , Jun 23, 2018 :
    *****I am also facing the same issue by 100 percent discharges to 30-40 in an hour or two. Before update there was never such issue***** help us with this bug really fast. Also while the phone is ideal, it gets heated unnecessary op5. Why this Android showing max battery usage.
  5. Rudra_binith
    Donut Jun 29, 2018
    Rudra_binith , Jun 29, 2018 :
    yeah true after 2 charging cycles , it became stable !!!
  6. PalSaurabh_007
    Cupcake Jun 29, 2018
