Battery draining overnight via OnePlus 7 Mirror Gray
  1. runforfun
    Gingerbread Jul 3, 2020
  2. Artemus.
    Nougat Jul 3, 2020
    Artemus. , Jul 3, 2020 :
    There's a multitude of reasons, specifically "background data usage" and the natural escaping of electrons.
  3. runforfun
    runforfun , via OnePlus 7 Mirror Gray , Jul 3, 2020 :
    My mobile data is turned off, and battery saver is On..
  4. Artemus.
    Nougat Jul 3, 2020
    Battery saver does really nothing, all it does is slow the CPU clocks to conserve as much battery as possible (at low levels). There's still background data being used regardless.
    runforfun likes this.
  5. runforfun
    Please give me a Solution...[e]1f61e[/e]
  6. Artemus.
    Nougat Jul 3, 2020
    There is no solution, it's just how batteries work. If it's at ~70% down from ~80% this is completely normal.
  7. runforfun
    I'm changing the battery 20% to 80% , is it good or bad to the Battery life..?
  8. Artemus.
    Nougat Jul 3, 2020
    Good. The longer you keep it on the charger the better.
  9. runforfun
    Artemus. likes this.
  10. M1584302034478
    Cupcake Jul 12, 2020
    M1584302034478 , Jul 12, 2020 :
    Try AccuBattery or Aida64 to check the specs and health of your battery
    Using AccuBattery i found out that my battery lost ~10% in 9 months.
