3
Battery Draining too much after Oreo
  1. akaditya15
    Froyo Jan 15, 2018
    akaditya15 , Jan 15, 2018 :
    Earlier according to my usage which is very less I charged 89% in nougart and it used to last 25..26 hours because i use phone less now after oreo has come it last very less like 12..13hrs. Battery is draining at a very fast rate.
    will oneplus fix this in any further update?
  2. akaditya15
    Froyo Jan 15, 2018
    Cellular networks is taking tol much I have a jio primary sim and other signal in sim 2
  3. Satish Sagi
    Cupcake Jan 15, 2018
    Satish Sagi , Jan 15, 2018 :
    I faced battery drain back when I used jio sim. I'm using airtel and Vodafone now. Battery backup is pretty good now.
  4. G_sachin_dabral_RgIV
    Froyo Jan 15, 2018
  5. G_ayush_aggarwal_TaGA
    jasti5 likes this.
  6. F_Catarina_Barroso_uuaI
  7. jasti5
    Eclair Jan 15, 2018
    C1511758639292 likes this.
  8. F_Jhn_B_LLy_Carranza_bJq
    Gingerbread Jan 15, 2018
    F_Jhn_B_LLy_Carranza_bJq , Jan 15, 2018 :
    after u update ur device, just go clean cache ...and wait for sometime for it to adjust from the day it was updated thats how the update works. not as the time u updated ur device system.
    Guilherme Fontes likes this.
  9. akaditya15
    Froyo Jan 16, 2018
    akaditya15 , Jan 16, 2018 :
    how to clean cache?
  10. akaditya15
    Froyo Jan 16, 2018
    Do you think they will fix it in a update?
  11. F_Jhn_B_LLy_Carranza_bJq
    Gingerbread Jan 17, 2018
  12. akaditya15
    Froyo Jan 17, 2018
    akaditya15 , Jan 17, 2018 :
    I have cleared the cache data which was like 5..6gb, and restarting the phone now, but how does this help in battery draining issue?
  13. D1511452227955
    Cupcake Jan 17, 2018
  14. sourabh93
    Eclair Jan 17, 2018
    sourabh93 , Jan 17, 2018 :
    I am having the same issue, after the update battery is draining drastically. cleared cache and still having the same problem.
    akaditya15 likes this.
  15. sojwals
    Froyo Jan 17, 2018
    sojwals , Jan 17, 2018 :
    similar problem I'm facing in my mobile after Oreo update and I'm observing since couple of days battery took 35-40 miutes to charge from 90-100% and draining very fastly. Now battery backup is 10-12 hrs on standby and while on continuous use its giving only 6 hrs. consulted with OnePlus Bug forum still didn't received any reply and didn't got any updates.
  16. fido_226
    Eclair Jan 17, 2018
    fido_226 , Jan 17, 2018 :
    I wipe cache from settings and recovery mode regularly and am still facing the problem of battery drainage. It's been 8 days since I had the update, which I think is quite a good time for the update to settle? In nougat the battery backup used to last for 23-24 hrs, now I have to charge my phone twice a day, the backup lasts for only 10-12 hours. I am spending the same time as I used to spend on screen.
    sojwals likes this.
  17. F_Catarina_Barroso_uuaI
    F_Catarina_Barroso_uuaI , Jan 17, 2018 :
    I don't know. I have noted that since yesterday it became better. The consume has now slowed down. Maybe it was the system looking for something. I don't know. You should wait a little more and see if it continues or slowes down. It does get better for me.
    sojwals likes this.
  18. F_Jhn_B_LLy_Carranza_bJq
    Gingerbread Jan 18, 2018
    F_Jhn_B_LLy_Carranza_bJq , Jan 18, 2018 :
    it clears up.minor bugs after an update ( clear cache) but if u still experiencing battery draining one thing u need to consider is look for any battery tips to activate beast mode of ur oneplus device, i went all thru nougat and oreo versions i never had experience or even once battery draining issues... i made a battery saver tips. i charge my battery and follow healthy battery tips too...
    yagna teja and sojwals like this.
  19. sojwals
    Froyo Jan 18, 2018
    sojwals , Jan 18, 2018 :
    exactly the same problem is with my mobile and I talked to customer service executives & they are suggesting to visit service centres for further help. even they (executive) couldn't be able to solve the problem.
    I hope they will fix this bug ASAP or provide a very stable Oreo update that will be very smooth for every Mobile
    fido_226 likes this.
  20. Jessica_Kolehmainen
    Cupcake Jan 18, 2018
    Jessica_Kolehmainen , Jan 18, 2018 :
    I did a factory reset after the Oreo-update, someone suggested it in another thread on this forum. That solved the issue with the battery for me.
