7
battery draining very fast on one plus 3T
  1. Kiran.a.joseph
    Jelly Bean Jan 4, 2017
  2. hunny959
    Cupcake Jan 4, 2017
    hunny959 , Jan 4, 2017 :
    update from Android 6 to 7 in consumption of 3 ℅ battery and after that 50℅ of battery consumed in whole day.Pretty much satisfied with the battery performance.awesome phone one plus flagship
  3. Abhishek Choudhari
    Cupcake Jan 4, 2017
  4. Donaldyan
    Donut Jan 4, 2017
    Donaldyan , Jan 4, 2017 :
    the same fast draing but just today, while i am on job, almost empty. first time this, still did not get 4.0/7.0 version 3.5.4
    all previous days I go home with 60-50%...
  5. thejnayan
    Donut Jan 4, 2017
  6. F_Paul_Dunning_ixyK
    Froyo Jan 4, 2017
    F_Paul_Dunning_ixyK , Jan 4, 2017 :
    haven't re charged mine since the day I got it !!!!
    Bought it this morning [e]1f602[/e][e]1f602[/e][e]1f602[/e][e]1f602[/e][e]1f602[/e][e]1f602[/e][e]1f602[/e][e]1f602[/e]lol lol
  7. F_Jagannath_Ramesh_rITo
    Cupcake Jan 4, 2017
    F_Jagannath_Ramesh_rITo , Jan 4, 2017 :
    in the battery settings, check the battery Optimizer option and select the apps that drain your battery. also high power consuming application closing option can also help in saving. give it a try and let us know if it helps. I haven't updated my OS yet. there is no point is having a dead phone in your pocket!
  8. Kiran.a.joseph
    Kiran.a.joseph , Jan 4, 2017 :
    I get better battery performance after nougat update. I used to get 8 hours of SOT and it lasted for 2 days in MM. After Nougat update, I get mlre than 10 hours SOT and battery lasts more than 2 days.
    I have aggressive doze mode turned on for all apps and Auto app-launch restrictions turned on for selective applications
  9. arnab0207
    Cupcake Jan 4, 2017
    neo_bpm likes this.
  10. Praty_28
    Jelly Bean Jan 5, 2017
    Praty_28 , Jan 5, 2017 :
    Wow 6 hours of SOT thats really cool i get max 4.5 hrs cos i use vpn and play online games 24/7 xD
    20-30% drop in just 2-3 hours thats a lot of drain.. Just install greenify it helps a lot... I lose only 1-2% overnight (7-8) hrs. standby time has increased a lot after installing and using greenify. Before using greenify Truecaller and es file explorer were the apps which consumed the highest amount of battery. Check if u got these apps.
  11. Jagfi
    Eclair Jan 5, 2017
  12. Jagfi
    Eclair Jan 5, 2017
  13. F_Eli_Morgan_esDO
    Cupcake Jan 5, 2017
  14. G_Thim_Soon_Chan_eTxn
    Eclair Jan 5, 2017
  15. Mitch_Cook20
    Eclair Jan 5, 2017
    Mitch_Cook20 , Jan 5, 2017 :
    To be fair this is a large problem, you cant just ignore it by praising the charger.
  16. Baibhav_Kumar
    Honeycomb Jan 5, 2017
  17. Jagfi
    Eclair Jan 5, 2017
  18. Jagfi
    Eclair Jan 5, 2017
    Jagfi , Jan 5, 2017 :
    look when my phone is idle battery drops by few percentage that's it but,when I use it it drops a percent in every 4mins
    #38
  19. Jagfi
    Eclair Jan 5, 2017
    #39
  20. Jagfi
    Eclair Jan 5, 2017
    #40
