battery draining
  1. N1569171939442
    Gingerbread Dec 23, 2019
    N1569171939442 , Dec 23, 2019 :
    battery is draining overnight even its in flight mode and wifi is off .. of about 10 to 15% .is its normal ?
    AbhiPatel6896 likes this.
  2. AbhiPatel6896
    AbhiPatel6896 , Dec 23, 2019 :
    no it's not normal.. try clearing cache and do a factory reset.. maybe it will help you a lot.. try it and update back if the problem is solved.. [e]1f609[/e][e]263a[/e]️
    N1569171939442 and Bilalazeem54 like this.
  3. N1569171939442
    i want to roll.back to pie ..it was best ..
  4. N1569171939442
    i did everything ..i also made reset the device and also wiped data and cache next time ..but its a nightmare ..
  5. AbhiPatel6896
    no brother.. actually android 10 is better than pie.. it's just because you are facing problem, else everything works great.. i always get 10+ hours of SOT.. and never faced any bugs..
    Artemus. and N1569171939442 like this.
  6. N1569171939442
  7. N1569171939442
  8. N1569171939442
  9. AbhiPatel6896
  10. N1569171939442
  11. AbhiPatel6896
    no man everything is normal and ON.. every battery eating settings are ON .. sync for google account is ON and everything else is same as a regular OP6T.. even i was shocked with the performance after updating to Android 10.. [e]1f609[/e]
    N1569171939442 likes this.
  12. N1569171939442
    okay bro ..and i game a lot .. really a lot .. continuosly for 3 to 4 hours .. and then battery drops from 100 to 25% ..like that in low settings and high frame rate ( COD ) and forget to mention ..in A10 game is crashing after every 1 hour of continuos gameplay
  13. AbhiPatel6896
    yes there is a bug with A10 which keeps on crashing the game.. but i am not a gamer so didn't came in contact with a bug like that.. but yes, if you play games heavily then you'll not able to get a good SOT... so there is a choice between games and SOT.. [e]1f601[/e][e]1f601[/e]
  14. liutieguan
    Cupcake Dec 23, 2019
