Battery draining via OnePlus 7T
  1. vinothvardha
    Donut Nov 21, 2020 at 8:28 AM
  2. Horsault
    Nougat Moderator Nov 21, 2020 at 9:01 AM
    Horsault , Nov 21, 2020 at 9:01 AM :
    No issue here, you can't use hotspot without using energy to intensely use both data and wifi networks.
    This, despite the fact that you either mistyped or chose wrong subforum.
    Marcus1984 and Sheppards like this.
  3. Chandroo Shiv
    Eclair Nov 22, 2020 at 5:51 AM
    Chandroo Shiv , Nov 22, 2020 at 5:51 AM :
    Using hotspot while work from home increases battery drain. I also face the same. But its not an issue. Try not to use mobile while using hotspot which may cause mobile to heat exponentially.
    Marcus1984 likes this.
