Battery draining via OnePlus 9 Pro
  1. somiljain7
    Froyo May 18, 2021
  2. the_o2
    OnePlus 9 Series Expert Community Expert May 18, 2021
    the_o2 , May 18, 2021 :
    Is draining at overnight?
    Can you post battery usage screenshots.
    Caoimhín likes this.
  3. somiljain7
    Froyo May 18, 2021
  4. matiasmc7
    Cupcake May 18, 2021
  5. Dipjyoti Nath
    OnePlus Bug Hunter Staff Member May 18, 2021
    Dipjyoti Nath , May 18, 2021 :
    We are sorry to hear that you are facing such an inconvenience with your device and thereby have contacted you through direct message for further details.
    Regards,
    Dipjyoti
    somiljain7 likes this.
  6. Dipjyoti Nath
    For analyzing this better we would need more details to get this sorted out. We've dropped you a personal message and thereby would request you to kindly respond to the same.
    Regards,
    Dipjyoti
  7. satej1995
    Froyo May 18, 2021
  8. somiljain7
    Froyo May 19, 2021
    somiljain7 , via OnePlus 9 Pro , May 19, 2021 :
    I agree with you, the company should correct the drainage issue with an update
  9. somiljain7
    Froyo May 19, 2021
    Thank you ma'am,but as a doctor I'm getting very less time for the log kit activity you sent me , especially in these times,it will be appreciable if you can help me in other way.
  10. Tokolozi
    Most Original Avatar May 19, 2021
    Tokolozi , May 19, 2021 :
    You can run a log kit in the background an pull it when you have time. Especially for a case where it's about battery drain in stand-by usage.
    the_o2 and Arjun_Choudhry like this.
