15
Battery full charge notification alert.
  1. G_Vishal_Gupta_BNuJ
    Gingerbread Nov 16, 2017
  2. disha parchani
    Donut Dec 29, 2017
    disha parchani , Dec 29, 2017 :
    Yes, it would be great! Even I am in the favor to get the luxury of this feature.
    Are you looking to get alerted when your battery is full?
    I use a Battery App which is very helpful for me. I think it will help you too.
    Ved Rai likes this.
  3. Onkar.Singh
    KitKat Dec 29, 2017
    AmanType, Abin_123 and G_Mr_.... like this.
  4. Deactivated User
    Dec 29, 2017
  5. Argonautis
    Donut Jun 7, 2018
    Argonautis , Jun 7, 2018 :
    Why use battery apps when you can have this as an integrated future? This is one of the first things I thought when I got my new phone.
    BTW for the post that says green light is sufficient... I don't think that's enough. And battery life is way greater when you don't overcharge it.
    Can we please have this for OnePlus 6 as well please!
  6. Wackencorpse
    KitKat Jun 7, 2018
    Wackencorpse , Jun 7, 2018 :
    Really a nice idea. The green light is okay, but I think an alert would be better. I will give TMK Battery Alarm a chance...
  7. Argonautis
    Donut Jun 7, 2018
    I just downloaded Battery HD and I will give it a try. But why can't we have this integrated? We have notification for low battery we should have one for fully charged battery as well.
    Someone mentioned something about the phone stop charging when its 100% is that the case??
    C1547736059172 likes this.
  8. zeus akash
    Eclair Jun 7, 2018
    zeus akash , Jun 7, 2018 :
    Also the charger has an auto switch off function whenever the battery is full, so you don't have to be worried about overcharging your phone.
    Dami Agunbiade and G_Mr_.... like this.
  9. Dvynshu
    Froyo Jun 7, 2018
    Dvynshu , Jun 7, 2018 :
    Well.... it's a good feature to integrate......it should be able to be customized at any number(percentage of battery) as per one's need.....
    It's definitely a handy feature.....
    Argonautis likes this.
  10. OnePlus OxygenOS
    Honeycomb Jun 7, 2018
    OnePlus OxygenOS , Jun 7, 2018 :
    hmm, I normally just charge when it's hit below 10% to the point it cuts off automatically since I'm always using a power bank...
  11. Argonautis
    Donut Jun 7, 2018
    But battery life is optimised when it runs at mid levels...
    If we overcharge then it's the same as draining them.
    Nice trick thought.
    Are you trying to optimise the life of your power bank?
  12. vasueza
    Gingerbread Jun 7, 2018
  13. OnePlus OxygenOS
    Honeycomb Jun 8, 2018
    OnePlus OxygenOS , Jun 8, 2018 :
    yeah I did read up on battery maintenance, to charge between 20 & 80% but I normally don't coz I get 2 full days use when I hit 100% each time...gonna see how long before my phone eventually dies out on me.
  14. Argonautis
    Donut Jun 8, 2018
    Argonautis , Jun 8, 2018 :
    Anyone know what is going on with the charging when it reaches 95%? I installed Battery HD yesterday and activated the 90/95/100%. So it charges to 95% in like half an hour but then takes another 30-40 minutes to reach 100%.
  15. Argonautis
    Donut Jun 8, 2018
  16. Artemus.
    Community Hero 2020 Jun 8, 2018
    Artemus. , Jun 8, 2018 :
    Once it hits 90% the charge speed decreases as it doesn't need the extra voltage to get to 100%. It's good practice to stop at ~80% to preserve longevity of the battery anyway.
  17. kumar alok2091
    kumar alok2091 , Jun 8, 2018 :
    overcharging it for 5 to 10 min can will keep ur battery in good condition...even OnePlus knows it....u will know it when u charge ur phone when it's switched off.....after 100% keep charging it....after 5 to 7 mins...tick mark will appear inside the battery icon....now unplug your device and switch it on....u will get better sot ,this helps me...u might find it useful too
  18. kumar alok2091
    that's not the case with my device....yea it takes time...but not that much
  19. ttoennies
    Cupcake Jun 8, 2018
    ttoennies , Jun 8, 2018 :
    You can use Tasker to create this notification. Can be any combination of audio or pop-up that you would want.
  20. C1528619599428
    Cupcake Jun 10, 2018
