Battery help
  1. Korothi Cupcake Jun 26, 2019
    Korothi, Jun 26, 2019 :
    I noticed it has Li-ion polymer battery not li-ion. What is the diffrence? How shoud i charge the battery? Is it good or bad to charge to 100% and keep charging and to deplete it to 0%?
  2. Aakash047 Froyo Jun 26, 2019
    Aakash047, Jun 26, 2019 :
    Both mean the same. It's recommended not to charge upto 100% or let the battery get below 30% to prolong battery life. Try to charge your battery in between when you get time, avoid letting it run out to 0%. Charging from 30% to 90% is best.
  3. Korothi Cupcake Jun 26, 2019
    Btw is there any app that stops charging once battery is 90%?
  4. Aakash047 Froyo Jun 26, 2019
    Not any I know of. Google it.
  5. MarkoBatrac Honeycomb Jun 26, 2019
    MarkoBatrac, Jun 26, 2019 :
    check accubattery
  6. chelsfc2108 Donut Jun 26, 2019
    chelsfc2108, Jun 26, 2019 :
    Charge as many times as you want, keep between 40% and 80%, never full charge or 0% it.
    Explained by Linus:
  7. Filepp Gingerbread Jun 27, 2019
    Filepp, Jun 27, 2019 :
    Use as you want, charge when you want, discharge as you want, no problem with new battery. I have friends that discharge their battery up to 1% often and no problem, i charge my phone overnight for 7 hours and no problem. Battery is the last problem of phones
  8. Korothi Cupcake Jun 27, 2019
    Korothi, Jun 27, 2019 :
    i do not buy new phone every 3 weeks sir.
  9. Filepp Gingerbread Jun 27, 2019
    My friend too... They use iPhone for 2 years, s9 for 2 years, no problem. I change often and sure for me is not a problem but i've understand that battery is never a problem. If you take care it live 3 years, if you not take care 2 moth less.
  10. Liehjan KitKat Jun 27, 2019
    Liehjan, Jun 27, 2019 :
    Used my op5 for two years, always charged it to 100%... battery life was almost the same as on day1 with the same SOT
  11. anupritaisno1 KitKat Jun 27, 2019
    anupritaisno1, Jun 27, 2019 :
    Charge all the way to 100%. No damage will be observed
    It is the discharging that kills your battery and not the charging. Do not discharge your battery to a level close to 0
    Also accubattery is garbage. Uninstall it
  12. anupritaisno1 KitKat Jun 27, 2019
    Linus is wrong. In fact is he ever right? I can only imagine somebody paying him to write up this garbage
  13. Korothi Cupcake Jun 27, 2019
    i agree with charging to 100% but why you think accubattery is bad?
  14. Korothi Cupcake Jun 27, 2019
  15. anupritaisno1 KitKat Jun 27, 2019
    Selinux doesn't allow applications to see how much battery is exactly being used. Accubattery has the same amount of battery data as any other user app on the system. Android also doesn't allow apps to run in background unless they keep a persistent notification running. This means that accubattery must constantly keep the system awake just to perform some "measurement" that has no relation with what's actually going on because the kernel won't allow it to read out the actual data
  16. Korothi Cupcake Jun 27, 2019
    I agree that it actually drains battery to save battery. i mostly use it to tell me when phone is 80%.
    What about linus? I know that li-ion battery shoudnt be drained too much.
  17. anupritaisno1 KitKat Jun 27, 2019
    When your battery is at 80% of it's original capacity what happens when you charge it to just 80%? Your phone shows the percentage relative to the current battery state so you actually charge to just 64% in comparison to the reference battery. On the other hand you'd have 80% in comparison to the reference battery by charging it to 100%
    Do the calculations yourself
  18. Korothi Cupcake Jun 27, 2019
    Ok so you are saying phone shows percentage of battery rated capacity(3880 for 1+7pro)? Any source why you think so? Because if that's the case you are right.
  19. anupritaisno1 KitKat Jun 27, 2019
    Nope "the phone shows the battery percentage relative to the current battery state" is what I said
    Start with 3.88Ah
    Let's say your battery is at "80% health" as accubattery supposedly claims
    That's about 3.14Ah usable capacity
    Now charge this to 80%
    You will charge this to 2.4832Ah
    What is 2.4832Ah to 3.88Ah? It's exactly 64%
    In other words charge a battery with 80% health to 80% charge and you actually get just 64% actual usage from that battery
  20. Korothi Cupcake Jun 27, 2019
    So you are supposed to charge it 80% of its actual health? i dont understand your point. What linus said is keeping the battery between 40 and 80 is good. even if its health is lower.
