14
Battery is insane
  1. Josepozuelo10
    Froyo Jun 27, 2017
    Josepozuelo10 , Jun 27, 2017 :
    Thanks, I hope that the new OTA resolves my problem
    #41
  2. yfan
    Honeycomb Jun 27, 2017
    yfan , Jun 27, 2017 :
    No, it's not acceptable. But out of an abundance of caution, I'd make sure you aren't charging with another fast charger. Either use Dash charge or a standard USB type C.
    #42
  3. bejaranojm
    Cupcake Jun 27, 2017
    #43
  4. _dhavan
    #44
  5. G_Alvin_Malave_eKMT
    #45
  6. PhilippVandrey
    Froyo Jun 27, 2017
    PhilippVandrey , Jun 27, 2017 :
    I just got 4,5 h SOT but 1d 10h from last charge.
    What are you doing for those insane 8h?
    Ich have the 8Gb/ 128Gb Model.
    #46
  7. faizwaris
    #47
  8. antonior93
    antonior93 , Jun 27, 2017 :
    Probably (many of them) are getting more than 5-6hrs by using it all day, so no more of 14-18hrs of total use.
    You used it for 1d 10h, and got 4,5h SOT, which is impressive i'd say!
    Consider that keeping the phone idle will drain some battery anyway
    #48
    PhilippVandrey likes this.
  9. The1Lion
    Marshmallow Jun 27, 2017
  10. clayginn
    KitKat Jun 27, 2017
    clayginn , Jun 27, 2017 :
    Whats a Blackberry
    #50
  11. sewell.davidj
    Donut Jun 27, 2017
    #51
  12. Akhilmah
    Froyo Jun 27, 2017
    #52
  13. Joshsor
  14. Katonhosenka
    Eclair Jun 27, 2017
    Katonhosenka , Jun 27, 2017 :
    I find the screen on time is always insane for the first few weeks of a new device, then it drops off dramatically a few months later. My s7 used to get 4.5-5 hours but now I'm lucky if I can get 3-3.5 hours. I think the same happened on my op1 and concerned would happen if I got a op5
    #54
  15. bpwest80
    KitKat Jun 27, 2017
    bpwest80 , Jun 27, 2017 :
    I agree. I used the phone for 4hr 30min pretty much straight yesterday with 4hr SOT and the battery was only down to 53%. Battery life seems great so far.
    #55
  16. yfan
    Maybe, but I have never even heard of a modern smartphone (let alone one as thin as the OP5) having anything close to an 8 hour starting SOT on a single charge. It depends on use, heating, battery decay, apps, and a whole lot of other factors, but even if SOT settles at about 75-80% of what one gets at the very beginning, an 8-10 hour beginning life translates to 6.5-7.5 hours of settled SOT. That's not bad at all.
    #56
  17. roshik2016
    #57
  18. Deactivated User
    Jun 27, 2017
    #58
  19. mattvan87
    mattvan87 , Jun 27, 2017 :
    Dash Charge is seriously amazing! I thought I wanted QC when I got my S8+ and it basically would barely charge if I was using it in the car. With my OP5 I basically only have to charge it while I am showering or driving and it charges up enough for the day!
    #59
  20. abhijeet.chaubey
