battery issue or not??
  1. raghavrajpillai
    Cupcake Feb 21, 2017
    raghavrajpillai , Feb 21, 2017 :
    I have noticed as well that battery drain on data is very high.. I need to kill all background apps to reduce it..
    F_Kuntal_Roy_IQcV likes this.
  2. G_Pawel_Kaminski_yHQk
    Eclair Feb 21, 2017
    G_Pawel_Kaminski_yHQk , Feb 21, 2017 :
    I have not included the option of programming and have this option in the battery.
  3. Bharat_sharma_579
    Gingerbread Feb 21, 2017
    Bharat_sharma_579 , Feb 21, 2017 :
    my battery drain too fast..developer mode on,aggressive doze off ..net on..10-15% battery down. Tried all stuff still battery drain is too much latest update installed :(
  4. Master_TC
    Jelly Bean Feb 21, 2017
    Master_TC , Feb 21, 2017 :
    Settings - About Phone - at the very bottom you will see "Build Number" - tap it 7-8 times and it will say "You are now a developer!" - now go back to settings an you will have a new menu "developer option" - go into this menu and activate it - activate "doze mode" too
  5. Master_TC
    Can you see which app drains your battery? Look in battery stat.
  6. Bharat_sharma_579
    android os...i hv evn uninstalled fb
  7. william bliss
    Eclair Feb 21, 2017
  8. prakash_diwakar
    Honeycomb Feb 21, 2017
    prakash_diwakar , Feb 21, 2017 :
    it depends on your mobile network in ur area too. check in battry uses details about the signal strength. if its red or orange it will consume more battery , even in idle , everything stopped.
  9. prakash_diwakar
    check signal strenth in battery uses details. if mobile signal strength shows red or orange, this will consume more battery even id idle phone with everthing off.
  10. G_Rushikesh_patil_vTyP
  11. F_Kuntal_Roy_IQcV
    F_Kuntal_Roy_IQcV , Feb 21, 2017 :
    my previous Samsung device drain only about 2/3% overnight.
  12. F_Kuntal_Roy_IQcV
  13. rishabhsahni
  14. din100
  15. manickalai
    manickalai , Feb 21, 2017 :
    thx, it's works good
  16. G_Braulio_Fernández_LeL
    G_Braulio_Fernández_LeL , Feb 21, 2017 :
    No pierdo% Durante la noche .. amanece con el 100% de la bateria con 7 horas de reposo. Y Durante El Día llego un 5.45 horas de Pantalla y el tiempo maximo desde la ultima carga fue de 23horas con OP3t 4.03
  17. vachanchaudhari
    Froyo Feb 22, 2017
    vachanchaudhari , Feb 22, 2017 :
    hey guys comment hear how many battery drains over night
    my oneplus 3t is drops 10% battery drains over night
  18. Master_TC
    Jelly Bean Feb 22, 2017
    #38
  19. webpatrick
    Honeycomb Feb 22, 2017
    webpatrick , Feb 22, 2017 :
    I didn't loose battery drain over night... it still drains :D
    But now for real. I put my device in Airplane mode overnight and loose about 1 % or 2 % overnight.
    #39
  20. Estevess
    Cupcake Feb 22, 2017
    #40
