Working battery issue
  1. divyanshu11
    Cupcake Jun 21, 2019
  2. Neddard
    Lollipop Jun 21, 2019
    Neddard , Jun 21, 2019 :
    It depends on what you're doing with your phone. Without a lot more info, no one can even speculate.
    Post your battery status and details pages to start.
  3. Gav_W86
    Moderator Moderator Jun 21, 2019
    Gav_W86 , Jun 21, 2019 :
    battery use depends mostly on your use, what apps you have installed, and what settings/services are running.
    what do the battery use screens in settings say is using your battery?
    best to look after a full (100% to <10%) single charge use for best info.
    you can post screenshots (both the 1st screen that says screen on time and the app use screen) here if you need assistance interpreting.
    Also, which phone? which OS version?
