5
Battery/Charging Battery issue
  1. sidnagpal1
    Ice Cream Sandwich Jan 10, 2017
    sidnagpal1 , Jan 10, 2017 :
    I'm on the latest os 4.0.1 and the battery was working fine but Thought of doing the calibration of the battery so I let it drain to 0% and then I charged it completely till 100% but after that now it's giving me very bad back up. It has drained 20% in just 30 mins. Plz help me out now
  2. Kiran.a.joseph
    Jelly Bean Jan 10, 2017
  3. TweakIt
    Honeycomb Jan 10, 2017
    TweakIt , Jan 10, 2017 :
    Did you do a factory reset after the install?
    Also do a cache clear after installing all the apps.
    Cheers! :)
  4. Piyush Tilara
    Cupcake Jan 10, 2017
    docbabloo likes this.
  5. bviengthong
  6. Piyush Tilara
  7. darrenhw
    Donut Jan 10, 2017
    darrenhw , Jan 10, 2017 :
    Everyone seems to be having the same issue. Uninstall Facebook and Facebook messenger. This drastically improves the problem but it doesn't fix it completely. We need an update ASAP.
  8. sidnagpal1
    Yes I have done that twice
    G_T._A._CxNO likes this.
  9. hmaiszem
    Eclair Jan 10, 2017
    hmaiszem , Jan 10, 2017 :
    i have same problem the battery was great on 4.0 after the last update its draining like crazy.
    Hope to get a solution for this
  10. sidnagpal1
  11. iNtEnSePL
    KitKat Jan 10, 2017
    iNtEnSePL , Jan 10, 2017 :
    uninstall FB, also Whatsapp - check how phone behaves, then if all is OK, install Whatsapp (I'm using it, doesn't give any problems), if all is OK, you can try FB again (but that is confirmed battery waster recently by many)
  12. sidnagpal1
    But the phone was working fine until I tried this calibration and now I regret doing that
  13. iNtEnSePL
    KitKat Jan 10, 2017
    when you drained battery, some processes went to sleep. After charging, they all woke up (may be that also these which we don't know about), and apart from that, they may be doing all updates not possible while they were asleep. So by catching up they eat battery.
    Use the phone as is, after a few charging cycles (normal), all should be OK (if there are no other issues we know not of)
    snjohn likes this.
  14. G_Saurabh_Gohil_mumv
    G_Saurabh_Gohil_mumv , Jan 10, 2017 :
    guys...I'm having the same issue. it's bad...like really bad... battery drains like shit...someone should address this asap!!
  15. G_harikrishna_sai_KsQW
    Donut Jan 10, 2017
    darrenhw likes this.
  16. S_bass
    S_bass , Jan 10, 2017 :
    Also an issue on mine.. [​IMG]
    The battery is crashing done, need to know a bit more on this subject.. The phone is hot on the up rear side..
  17. TweakIt
    Heat can kill your battery rapidly, which is also why it's not a good idea to charge 0-100%. Wait for it to cool down yes? Stay off WhatsApp for a while if you can. Let the phone stabilize. And then check battery stats :)
  18. sidnagpal1
    The battery performance has improved the SOT is of 2 hrs and still 60% battery is remaining
    TweakIt likes this.
  19. TweakIt
    YES! That's what I am talking about. Give it time.
    Happy to hear your good news.
    Cheers! :)
    snjohn likes this.
  20. G_BISWAJIT_BHOWMIK_iCro
    Cupcake Jan 13, 2017
