5
battery issue
  1. imrana1986
    Cupcake Mar 31, 2017
    Saurabhmik likes this.
  2. Arsath1994
    Froyo Mar 31, 2017
    Arsath1994 , Mar 31, 2017 :
    yup!..
  3. Karthikapple
    Karthikapple , Mar 31, 2017 :
    yup...me too
  4. sundarvenkat
  5. fordsuresh
    Donut Mar 31, 2017
    fordsuresh , Mar 31, 2017 :
    For me, it shows during charge Green with Pass means it's getting required power to the battery.
  6. kmohit14
    Froyo Mar 31, 2017
  7. G_Harishankar_Gupta_xdac
    Donut Mar 31, 2017
  8. G_Harishankar_Gupta_xdac
    Donut Mar 31, 2017
    G_Harishankar_Gupta_xdac , Mar 31, 2017 :
    okk
    so should I buy mivi cable or op2 cable??
  9. piyushgaur026
    Cupcake Apr 1, 2017
    piyushgaur026 , Apr 1, 2017 :
    Battery Issues :: I got a new phone OnePlus 3T 4 days back battery is draining very fast. Today morning I charged 100% and it's 4.5 hours battery is left with just 36%. Please let me know if it's normal or I should get my handset replaced
    TIA
  10. kt997
    Gingerbread Apr 1, 2017
    kt997 , Apr 1, 2017 :
    dude you just have to clear cache and then wait for few charging cycles..
    to clear cache:
    1. turn off your phone.
    2. press and hold volume down and power button until the phone vibrates.you will then enter recovery menu.
    3. select english.
    4. select wipe cache/data.
    5. select wipe cache.
    6. if prompt comes ..select yes.
    7. then reboot.
    8. done.
    piyushgaur026 likes this.
  11. piyushgaur026
    Cupcake Apr 1, 2017
    does this looks fine ??
    just now plugged the phone into charger in just 5-6 mins the battery got charged for like 10%
  12. Raghavsinghal
    Cupcake Apr 1, 2017
  13. bhavani singh
    Donut Apr 1, 2017
    bhavani singh , Apr 1, 2017 :
    Charging and battery issue solved,
    I was also facing the same issue than somewhere i read, the problem is solved after clearing the cache and data, follow these steps:
    - take the backup of all your data
    - then switch of the phone
    - then press volume down + home botton
    - then select wipe cache and data
    - then restart your phone
    Thts it all done.. Keep smiling
  14. Deactivated User
    Apr 1, 2017
  15. surajkrdubey
    Cupcake Apr 1, 2017
  16. G_Miikepoike_bKwa
    Cupcake Apr 1, 2017
  17. architsureka
    Cupcake Apr 2, 2017
    architsureka , Apr 2, 2017 :
    Hi,
    I am facing an unusual battery drain for the last couple of days and the biggest source of this drain is Googlr Services.
    Looking further into it shows that Google Play Services are the biggest drain. When i look further in the system settings under Battery it takes me to the LOCATION Services when I click on Google Play services.
    The location setting is at "Device Only" which is jist GPS which I believe is te default setting.
    Pls can someone help me sort this major Battety drain issue.
    thanks
    OP3 user, 6 months old phone, all updates applied
  18. G_Harishankar_Gupta_xdac
    Donut Apr 7, 2017
    G_Harishankar_Gupta_xdac , Apr 7, 2017 :
    guys I don't know how but the problem of slow charging has been resolved
    now it takes about 3hrs for complete charge with the same cable and adapter provided by OnePlus 2 although battety is draining fastly.
    #38
  19. _Burhan_khan_
    Cupcake Apr 7, 2017
    #39
  20. ram1987
    Gingerbread Apr 8, 2017
    ram1987 , Apr 8, 2017 :
    Hi,
    Request to guys who ever say to change the cable.
    -I have been observing this guy in all the battery issue threads . He suggests to change the cable and that will solve the problem.
    - Can you please show the proof that changing cable solved this issue.
    - All our OnePlus 2 phones are working completely fine before update then after update how can cable get damaged and cause serious charging and discharge issue.
    - After update my phone takes atleast 6-7 hours to get ౩౦% Mark.
    My kind request to @OnePlus team is to solve this bug and make your customers happy.
    Good day....
    #40
