Battery Issue
  1. ananyapraneet
    Cupcake Mar 24, 2018
    ananyapraneet , Mar 24, 2018 :
    I left my phone on charging the whole night by mistake. Now the battery is draining faster than it usually does. What should I do ?
    Tmax101 likes this.
  2. ShinojR
    Froyo Mar 24, 2018
    ShinojR , Mar 24, 2018 :
    Can you provide more information. Is the battery drain faster only after you left it charging overnight? People say there is something called battery calibration. You have to charge your phone to 100% and then let it drain completely, again charge it to 100% and check. But technically leaving it charging overnight shouldn't be causing an issue because the design is such that phone prevents overcharging after it has reached 100%.
  3. sai.ch
    Gingerbread Mar 24, 2018
    sai.ch , Mar 24, 2018 :
    battery calibration????????
  4. ananyapraneet
    Yes it happened this morning. I can tell that the battery is draining faster than earlier. Usually it takes time but it's the middle of the day and the battery is already 55 %.
  5. Muzaffar Pasha Chiya
    Eclair Mar 24, 2018
    Muzaffar Pasha Chiya , Mar 24, 2018 :
    55% middle of the day is usual with my OP3T!!!
    deepak_jr11 likes this.
  6. Hengmeister
    Froyo Mar 24, 2018
  7. RASTAVIPER
    Jelly Bean Mar 25, 2018
    RASTAVIPER , Mar 25, 2018 :
    Totally irrelevant the 2 facts.
    Nothing to worry about or to ask for fixes.
    Cyanidebreathmint likes this.
  8. G_Blue_Vite_fuNN
    Froyo Mar 26, 2018
    G_Blue_Vite_fuNN , Mar 26, 2018 :
    i'm charging very often over the night. there ist no known cause of this. don't worry. it is either a new app or the user that caused the drainage
  9. G_Avee_B_Xaxb
    Jelly Bean Mar 26, 2018
    G_Avee_B_Xaxb , Mar 26, 2018 :
    i usually gets 15%-20% battery drain overnight before but since i disabled my "ok google detection" in the google assisstant settings, my battery overnight standby drain is reduced to 2-3% for 8hrs of sleep. I dont know the corelation between "ok google detection" and battery drain but i'm thankful batter draw is reduced.
