Battery Issue
  1. G_Romil_Sethi_hKDn
    Eclair Mar 31, 2018
    Ravi BINAVAT likes this.
  2. akash_05
    Froyo Mar 31, 2018
    akash_05 , Mar 31, 2018 :
    try keeping your phone in safe mode overnight to see whether this issue is caused by any third party apps.....
  3. danishajaz
    Gingerbread Mar 31, 2018
  4. akash_05
    Froyo Mar 31, 2018
  5. GokuUltraInstincts
    Jelly Bean Mar 31, 2018
    GokuUltraInstincts , Mar 31, 2018 :
    See if there's any apps that's draining your battery a lot and uninstall it.
    Or you can wipe cache.
    Go to settings, battery and advanced optimisation and see if that's turned on for every apps.
  6. G_Romil_Sethi_hKDn
    Eclair Mar 31, 2018
  7. akash_05
    Froyo Mar 31, 2018
    have u booted ur phone in safe mode?
  8. G_Romil_Sethi_hKDn
    Eclair Mar 31, 2018
  9. akash_05
    Froyo Mar 31, 2018
    then try keeping this over night..... and see whther the problem occurs or not.
  10. G_Romil_Sethi_hKDn
    Eclair Mar 31, 2018
    G_Romil_Sethi_hKDn , Mar 31, 2018 :
    ok I'll give this a try.
    thanks
  11. akash_05
    Froyo Mar 31, 2018
    hmm.... i hope this would help u figure out which app sucks ur battery.... try and post the results... dont forget
  12. themightypathan
  13. G_Romil_Sethi_hKDn
    Eclair Mar 31, 2018
    yes, actually it's all happening after the Oreo update. Nougat was flawless
  14. akash_05
    Froyo Mar 31, 2018
    this issue is not with update... it is app specific or any cache error.... i also faced the same issue with truecaller app... then the true caller app was given an update to support oreo and for fixing bugs.... problem solved.... so only i told you to keep an eye on apps u ve installed.... the safe mode supports this a lot...
  15. G_Romil_Sethi_hKDn
    Eclair Mar 31, 2018
    After booting up in safe mode what I have to do?
  16. akash_05
    Froyo Mar 31, 2018
    keep ur phone in safe mode while u re sleeping... it will not allow third party apps work... so u can find easily which app is cusing this problem....
  17. G_Romil_Sethi_hKDn
    Eclair Mar 31, 2018
    ok
  18. akash_05
    Froyo Mar 31, 2018
    check the battery percent for any decrease in the morning
    .. then reeboot ur phone after confirming that the problem has veen solved
  19. Ravi BINAVAT
    Ice Cream Sandwich Mar 31, 2018
    Ravi BINAVAT , Mar 31, 2018 :
    1. Go to phone dialer app and dial *#800#
    2. Select the first option which says “oneplus Logkit”, delete history log
    3. Click “save log”
    4. Go to settings-battery, and take a screenshot of the battery consuming situation
    5. Enter oneplus Logkit, choose “other log info”, click “get top info”, “battery history” every several minutes and “get bugreport info” once
    6. Go back, choose save log again to stop it.
    Finally, enter files>internal storage>oem_log, find the folder, zip it and send it to us along with the screenshot
    If battery drains most under normal use, please capture the log when you use normally. If it drains under long time standby, please start it before you go to sleep and finish when you wake up.
    It’s better to do it when battery is below 50%.
    Thank you very much for your time.
    akash_05 likes this.
  20. G_Romil_Sethi_hKDn
    Eclair Mar 31, 2018
