Battery issue
  1. Radha1698
    Cupcake Sep 21, 2018
  2. sony88
    Cupcake Sep 22, 2018
    sony88 , Sep 22, 2018 :
    do you mean its eating lot of power? I reset my phone now its working well
  3. F_Namit_Pal_ooNi
  4. S1537819634286
    Cupcake Sep 24, 2018
    S1537819634286 , Sep 24, 2018 :
    Yep, very common Problem! My Brother (One+2) has this problem when he uses mobile data. When he connects to wireless, everything is fine. I did have this problem as well at a former Wireless network at work. As soon as I did connect, I could the my battery going low and my phone heating up like the sun [e]1f602[/e] So I just don't use that network anymore, that's how I "solved" it
  5. Q1536919049080
  6. frankkn85
    Eclair Sep 24, 2018
    frankkn85 , Sep 24, 2018 :
    then try to keep double tap screen off and also disable automatic brightness. even some background apps makes usage of screen even when it's off and heats up the device.
    Q1536919049080 likes this.
  7. Photoman9988
    KitKat Sep 26, 2018
  8. Photoman9988
    KitKat Sep 26, 2018
    Photoman9988 , Sep 26, 2018 :
    Stop thread hijacking. This isn't even the correct section for your phone, moron.
    Aks41179 likes this.
  9. B1537121017600
    Cupcake Sep 26, 2018
    B1537121017600 , Sep 26, 2018 :
    How to connect wireless
  10. mihastih
    Eclair Oct 1, 2018
    mihastih , Oct 1, 2018 :
    change the battery and try again...if not working change the charging board
  11. K1538934258444
    Cupcake Oct 7, 2018
  12. Hemanttrimal
    Cupcake Oct 13, 2018
    Hemanttrimal , Oct 13, 2018 :
    Hi guys this is hemanttrimal
    Iam user of one plus 2 from past 3yrs
    I facing issues like battery drains quicker
    I would get atmost 5hrs screen on time
    And one plus has olso announced that op2 would not get ota update
    Would u guys suggest me a best and long lasting battery custom rom with appropriate
    Kernals
    Thanks
  13. Hemanttrimal
    Bro you can flash custom ROMs or switch to
    Buy a new phone
  14. Y1539450805866
    Y1539450805866 , Oct 13, 2018 :
    oneplus 2 mobile is dead all in one mobile oneplus 2 is dead to sale my contact number 9 4 54 85 76 10 call me at help you anybody my mobile its battery problem my address Gorakhpur up
  15. Y1539450805866
  16. Y1539450805866
    Kisi Ka Bhi mobile oneplus 2 bekar hai Tu Mujhe Ho De Sakta main Us mobile ka use kar sakta hoon mujhe us mobile ki battery chahiye purani bahut jarurat hey bahut jarurat hai contact kare mera number hai 94 5 4 8 5 76 10 Sampark Kare thank you
