Battery Issues OnePlus 6T
  1. NoahSN Donut May 20, 2019
    NoahSN, May 20, 2019 :
    Hi OnePlus community!
    I have a small issue regarding the battery life of my OnePlus 6T.
    I hear YouTubers talk about 6 - 7,5 hours of screen-on time, while my OnePlus 6T only lasts about 4 hours of screen-on time.
    I have Bluetooth, cellular and WiFi turned on all day, so that might influence the screen-on time, but still. 6,5 hours compared to 4 hours is a big difference.
    Can someone please help me out with this and explain what's going on?
    Thnx!
  2. Kytharsis Lollipop May 20, 2019
    Kytharsis, May 20, 2019 :
    When was the last time you calibrated the battery?
    Maverick2.0 likes this.
  3. NoahSN Donut May 20, 2019
    What do you mean with 'calibrated' the battery?
  4. danevans17 Ice Cream Sandwich May 20, 2019
    danevans17, May 20, 2019 :
    I wouldn't ever "calibrate" the battery as that usually involves using rubbish apps.
    Bluetooth will of course drain the battery a lot, especially if you have all 3 turned on all day, Bluetooth, WiFi and cellular.
    I have the 6 and get 6-7 hours screen on time as I only have whatever I need enabled at the time I'm using it. So therefore nothing is ever running that doesn't need to be.
  5. Maverick2.0 Jelly Bean May 20, 2019
    Maverick2.0, May 20, 2019 :
    Calibration of the battery would not involve any apps, AFAIK.
  6. NoahSN Donut May 20, 2019
    The thing is, I have a smartwatch. Therefore, my Bluetooth needs to be turned on all day. I also like to keep mobile data on, because I change locations frequently, and I of course don't have WiFi when I'm on the go (on my bike).
    danevans17 likes this.
  7. NoahSN Donut May 20, 2019
    Can you explain me what 'calibrating' your battery means?
  8. Maverick2.0 Jelly Bean May 20, 2019
    NoahSN likes this.
  9. Kytharsis Lollipop May 20, 2019
    Drain your battery to close to 0, charge it for about 6 hours past 100% (overnight is best) and your device should optimize the battery in this time resulting in better battery draw. Do this every update.
  10. NoahSN Donut May 20, 2019
    Ah, thanks! I usually use my phone all day till it's around 5% and then let it charge over night. I think that that should do the job. It unfortunately doesn't work for me.
  11. Kytharsis Lollipop May 20, 2019
    I see you do a lot of Snapchat. That could also be the reason.
  12. NoahSN Donut May 20, 2019
    Well, I'm not that often on Snapchat. It's mostly running on the background.
  13. Kytharsis Lollipop May 20, 2019
    That'll drain your battery more than you know.
  14. NoahSN Donut May 20, 2019
    I'm aware of that, but don't want to remove Snapchat. I use it to stay in contact with friends.
