Battery issues OnePlus 8T via OnePlus 8T
  1. Kishan MG
    Donut Jun 16, 2021
    Kishan MG , via OnePlus 8T , Jun 16, 2021 :
    I had battery percentage of 10-15% for some weird reason my phone got switched off at 8% it has happened twice... From 10 to nil and battery was drained fully. please fix this issue ASAP
  2. eddyros
    Honeycomb Jun 16, 2021
    eddyros , Jun 16, 2021 :
    I suggest you to send a feedback in order to make record of log and tech staff can understand better the problem/bug
  3. GiorgiV
    Cupcake Jun 16, 2021
    GiorgiV , Jun 16, 2021 :
    Have u been using your phone for gaming ? If you drain your battery every day through gaming and then fast charge immediately, it will worsen phones battery property and system problems may show up like that one u described.
    Several years ago when I still had IPhone 5s, battery would jump from 55% to 30 and then get 0 in 3 min. Obviously reason was battery, and if u remember Apple was sued for dis... because they made ios versions in that way to worsen battery...
    If that's not the case, you have system bug and submit ticket of error and system log to support it may help...
  4. W1604410546693
    Cupcake Jul 23, 2021 at 3:21 PM
  5. Z1627206743952
    Cupcake Jul 25, 2021 at 10:56 AM
    Z1627206743952 , via OnePlus 8T , Jul 25, 2021 at 10:56 AM :
    Really it happens? OMG i just bought my OnePlus 8t 8/128 . Bcoz i had OnePlus 5t 6/64 and had same issues. Very fast drain battery. And can't have 2 3 app in same time. Volume can't increase to max later my phone switch off automatically even battery was at %30 below.... Every time happened this so i buy new OnePlus 8t . Hopefully will not happen again to this phone
