10
Battery issues..!!
  1. G_Tharun_T.S_oadD
    Donut Apr 29, 2018
    G_Tharun_T.S_oadD , Apr 29, 2018 :
    Battery life by scaled down after 8.1 update on op5T. I was getting 6 hours of screen on time. Now it's reduced to 4-5 hours. Also noticed the charging time has gone up al little....
    And common still no update on the cameras!!!!
  2. ravishekhar1611
    Donut Apr 29, 2018
    ravishekhar1611 , Apr 29, 2018 :
    Yup. I too am facing the same issue. Battery consumption has increased drastically. Biggest chunk coming from ANDROID SYSTEM.
  3. the_o2
    User of the Year 2018 Apr 29, 2018
    the_o2 , Apr 29, 2018 :
    Yup, after every update there is hole formed in battery from where the battery started draining and by creating redundant threads it got filled.
    Clear the cache from recovery mode, it would help.
    Atleast check the pinned thread before creating redundant threads
    Pawcio62432 and Ravi BINAVAT like this.
  4. G_Douglas_Björklund_ahBx
    Cupcake Apr 29, 2018
    Ravi BINAVAT likes this.
  5. ravishekhar1611
    Donut Apr 29, 2018
    Hi, can you please provide a link to the pinned thread. Can't find it. thanks
  6. Maria Jerald
    Maria Jerald , Apr 29, 2018 :
    Hi. How to clear the cache from recovery mode?
  7. C1524986933004
    C1524986933004 , Apr 29, 2018 :
    me too have this issue....my battery drains down so quickly...and some times it may switch off automatically even if 30peecent charge is there
    Ravi BINAVAT and C1518711284998 like this.
  8. the_o2
    just do these 2 things..
    First: Go to setting->storage and memory (scroll down)-> cached data(click and clear the cache).
    and then
    Second: Wipe the cache partition by following step.
    1. Turn the phone off(unplugg the charger if charging).
    2. Hold Power and Volume Down
    3. English (or pick any language that you want)
    4. Wipe data & cache
    5. Wipe cache
    6. Yes
    7. Reboot.
  9. Ozair_Shaikh
    Ozair_Shaikh , Apr 29, 2018 :
    This happened to me
  10. Ravi BINAVAT
    Ice Cream Sandwich Apr 29, 2018
    Ravi BINAVAT , Apr 29, 2018 :
    1. Go to phone dialer app and dial *#800#
    2. Select the first option which says “oneplus Logkit”, delete history log
    3. Click “save log”
    4. Go to settings-battery, and take a screenshot of the battery consuming situation
    5. Enter oneplus Logkit, choose “other log info”, click “get top info”, “battery history” every several minutes and “get bugreport info” once
    6. Go back, choose save log again to stop it.
    Finally, enter files>internal storage>oem_log, find the folder, zip it and send it to us along with the screenshot
    If battery drains most under normal use, please capture the log when you use normally. If it drains under long time standby, please start it before you go to sleep and finish when you wake up.
    It’s better to do it when battery is below 50%.
    Thank you very much for your time
  11. ravishekhar1611
    Donut Apr 29, 2018
    Hi, how do I send you the zip folder?
  12. MikeG247
    Jelly Bean Apr 29, 2018
  13. ravishekhar1611
    Donut Apr 29, 2018
  14. MikeG247
    MikeG247 , Apr 29, 2018 :
    You could save it to your Google Drive and provide a link to your file.
  15. J1525001566862
  16. Z1515355786189
    Z1515355786189 , Apr 29, 2018 :
    how do I check this?
  17. ravishekhar1611
    Donut Apr 29, 2018
