2
Battery life and random rebooting
  1. Justin2384
    Donut Mar 26, 2015
    Justin2384 , Mar 26, 2015 :
    For the past few days my one has been using a lot of battery. Almost 10% a hour at times, looking at the usage it was android os usage. I denied wake and keep awake the os and battery seems a little better but not much. Now my phone has started random rebooting. Before I do a master reset (or throw the phone at a wall) has anyone else been having these issues in the past week or so. No new apps downloaded and the ones I did download most recent I removed
    anayahiren and menacho.eulogio like this.
  2. jckosten
    Gingerbread Mar 26, 2015
  3. DaxNagtegaal
    Marshmallow Mar 26, 2015
    DaxNagtegaal , Mar 26, 2015 :
    Battery is because of the google play services and the random reboots is because you ****** with the android system permissions. Reset privacy guard.
    guro47 likes this.
  4. menacho.eulogio
    Lollipop Mar 26, 2015
    menacho.eulogio , Mar 26, 2015 :
    Mine since last night the battery is having the same problem. Checked the settings and the one is using the battery is Google play services 40%.o_O Charged my phone twice in the last 14 Hrs. and I'm not even using the phone.
  5. Justin2384
    Donut Mar 26, 2015
    Yea I saw the Google play services was causing issues but didn't see anything about the android os usage skyrocketing
  6. mckenn
    Froyo Mar 26, 2015
    mckenn , Mar 26, 2015 :
    Seemed to start happening after the Google Play Store update to build 5.3.6. Has to be a bug. never experienced this before this week.
  7. Deactivated User
    Mar 26, 2015
  8. Justin2384
    Donut Mar 26, 2015
    I don't comment much on forums. Only if I have issues and wondering if other people are as well. Try to look through everything before I post no reason to duplicate post issues
  9. Fred S.
    Cupcake Mar 27, 2015
    Fred S. , Mar 27, 2015 :
    I am having significant battery drain from Google Play Services since Tuesday. What can be done about this?
  10. malidan
    Nougat Mar 27, 2015
    malidan , Mar 27, 2015 :
    Wow not much action on the forum, welcome to the true OPO experience. There are loads of random rebooting threads, so you should have no problem resolving your issue.
    As one of the elders do you also suffer from the dreaded yellow band that does not exist, also touch issues that don't exist either.
    I noticed you did say you posted when you had issues.
  11. addam
    KitKat Mar 27, 2015
    addam , Mar 27, 2015 :
    Change your CPU settings from interactive to conservative and youll probably get rid of the random reboots. You have to open developer options first. Settings>about phone>tap build number 7 times, then go back to settings. You'll see performance toward the bottom, this is where you adjust your CPU settings.
  12. Justin2384
    Donut Mar 27, 2015
    Justin2384 , Mar 27, 2015 :
    Never had any issues with the yellow band or touchscreen. My One always worked flawless for me until google updated the google play services. Hope Google/Oneplus comes out with a update. Seriously love the phone and waiting for either O2 or CM12
  13. yongcong
    Gingerbread Mar 27, 2015
    yongcong , Mar 27, 2015 :
    Yup..battery has been very bad these few days. Plus the update that Oxygen OS and CM12s being delayed is not helping.
  14. anayahiren
    Ice Cream Sandwich Mar 27, 2015
