Battery life bad?
  1. 12nitha
    Gingerbread Aug 15, 2014
  2. IWantOneNow
    KitKat Aug 15, 2014
  3. mjwhelan
    mjwhelan , Aug 15, 2014 :
    Reviews are saying its considerably better than average, you can get two days of average use from it!
  4. popimp315
    popimp315 , Aug 15, 2014 :
    Battery life is dependent on the user and apps. You also can look into rooting and underclocking, undervolting, etc. Hopefully it gets better.
    kshitijrai likes this.
  5. anirudhverma1990
    Froyo Aug 15, 2014
    anirudhverma1990 , Aug 15, 2014 :
    I'm coming from a phone which used to last just half a day. So I don't really see how the battery life of the Oneplus One is bad!
    P.S.- The above battery drain is when the wifi and 3G toggles were constantly switched to 'ON', on auto brightness and about 3-4 hours of bluetooth audio usage.
  6. ajaxkoen1993
    Honeycomb Aug 15, 2014
  7. prstorero
    Jelly Bean Aug 15, 2014
    prstorero , Aug 15, 2014 :
    Does the error say something about apply patch check for mixer_paths.xml?
  8. pmjohnson99
    pmjohnson99 , Aug 15, 2014 :
    It's all about apps and how you use it. 3100mAh probably can give an average use plenty of time between charges.
  9. shastada
    Ice Cream Sandwich Aug 15, 2014
  10. Stefs
    Stefs , Aug 15, 2014 :
    if reception is bad that also should drain battery faster!
  11. popimp315
  12. shastada
    shastada , Aug 15, 2014 :
    It should but doesn't. Thats probably part of the problem I think. The OPO isn't turning up the amp to try to get a better signal when it SHOULD be. Make sense? Thats why I think its a SW issue and not a HW one.
  13. ibiplob
  14. shastada
    2 days on battery, thats pretty good... How do you make the percentage show up in the circle? I don't have that.
    Deactivated User likes this.
  15. ckovac
    ckovac , Aug 15, 2014 :
    Cyanogen said they know about a drain on the latest update and are working on a fix.
  16. Stefs
    ibiplob likes this.
  17. Eridi4n
    Cupcake Aug 15, 2014
    Eridi4n , Aug 15, 2014 :
    You can set it up in your settings :)
  18. subhas_sing
  19. A.S
  20. edwmiguel
    Froyo Aug 15, 2014
