93
Battery Life issue IS FIXED, if drain was caused by Facebook!
  1. whodatboi
    KitKat Jan 11, 2017
    whodatboi , Jan 11, 2017 :
    odd. is Android system or Google play services #1?
    HEBF for services....Android system/os is OP bug
  2. Vladimír_Stopka
    Cupcake Jan 11, 2017
    Vladimír_Stopka , Jan 11, 2017 :
    i am still on 3.5.4 and also had the same issue yesterday with battery, fb app 25% messenger 15% android system 20%
    battery dead in 12 hours, usually it lasts 2 days
    i restarted the phone. it looks like it helped, i am not surr for how long
    robgti likes this.
  3. G_P-O_P_XHHX
    G_P-O_P_XHHX , Jan 11, 2017 :
    Édit of my post:
    Don't forget to set to normal the clear app options after this, otherwise you'll have bug everytime
    whodatboi likes this.
  4. mohanhappy
    mohanhappy , Jan 11, 2017 :
    even I had same issue, the battery drain faster then I uninstall Facebook and facebook mesager the. now it's fine.
  5. wospino
    Ice Cream Sandwich Jan 11, 2017
  6. G_Dries_Augustyns_CMji
  7. whodatboi
    KitKat Jan 11, 2017
  8. bpwest80
    KitKat Jan 11, 2017
    cata86fly likes this.
  9. F_Michal_Doblej_dBkm
    F_Michal_Doblej_dBkm , Jan 11, 2017 :
    depends on the usage i have been able to get about 6 hours of sot when gaming almost all the time with elementalx on oos 3.2.8
  10. chirag5497
    Donut Jan 11, 2017
    chirag5497 , Jan 11, 2017 :
    yes it definitely works. just uninstall Facebook and Messenger. and clear cached data and reboot. will improve ur battery life :)
  11. G_ΣTHΔΠ_X_REtJ
  12. Spelt
    Spelt , Jan 11, 2017 :
    Non-optimized apps as usual for when a major version of Android comes out. It takes some apps longer to fix the problems they are having with a major update. I call just being lazy.
  13. ddivakaran
    Froyo Jan 11, 2017
    ddivakaran , Jan 11, 2017 :
    I don't have both applications but my battery is draining so fast. This phone is good for nothing
  14. adhish_np
    Honeycomb Jan 11, 2017
  15. tarikul166
    tarikul166 , Jan 11, 2017 :
    battery is draining too fast even at the idle time also.I thought after getting nougat update problem will be solved but unfortunately nothing has changed.currenly I m using oxygen 4.0
  16. G_T._A._CxNO
    Gingerbread Jan 11, 2017
  17. ThePlainGamer
    ThePlainGamer , Jan 11, 2017 :
    Facebook did a update on the both apps who are using the CPU too much. FB knows this issue and they are working on it
    fonzobreaker likes this.
  18. kishelraj
    Eclair Jan 11, 2017
    kishelraj , Jan 11, 2017 :
    I recommend you to download Metal to replace facebook and messenger. it combines Facebook, messenger and Twitter while saving a lot of battery life and bloat.
    airiartev likes this.
  19. fonzobreaker
    fonzobreaker , Jan 11, 2017 :
    Facebook update today seems to have solved the issue
    Pretty average stats
    btw yesterday they already fixed Messenger server side issue
    (as already been posted)
  20. Brandon Ogon
    Donut Jan 11, 2017
    Brandon Ogon , Jan 11, 2017 :
    I use the actual app so little that this makes me decently upset. I want the notifications, not the battery drain.
