3
Battery life of OnePlus 6
  1. abhi8999
    Donut Dec 10, 2018
    abhi8999 , Dec 10, 2018 :
    What the hell is happening with my OnePlus 6
    Battery drains crazy with normal use
    I need to charge this phone 4-5 times daily
    moggers, rakesh_sivva and chinna2ali like this.
  2. F_Hersh_Shah_fqmw
    Froyo Dec 10, 2018
  3. abhi8999
    Donut Dec 10, 2018
    i tried factor reset nothing happened
  4. F_Hersh_Shah_fqmw
    Froyo Dec 10, 2018
  5. abhi8999
    Donut Dec 10, 2018
  6. F_Hersh_Shah_fqmw
    Froyo Dec 10, 2018
  7. F_Hersh_Shah_fqmw
    Froyo Dec 10, 2018
    F_Hersh_Shah_fqmw , Dec 10, 2018 :
    Try to figure out is it hardware issue or software issue there may be a app which is using battery in background.
  8. robin143
    Honeycomb Dec 10, 2018
    robin143 , Dec 10, 2018 :
    OnePlus is focusing more only on new devices.
    I will never buy the oneplus brand again. Samsung is good for providing stable update unlike OnePlus. My phone is facing heavy battery drain , heating issue and some minor bugs.
    We should post the problems of OnePlus brand in twitter Account and share it to everyone , let others know the problems of oneplus brand. Felt like wasted my money in buying this device.
  9. Android450
    Marshmallow Dec 10, 2018
    Android450 , Dec 10, 2018 :
    Check your apps then something is keeping your phone awake
  10. W1544428757666
    Cupcake Dec 10, 2018
    W1544428757666 , Dec 10, 2018 :
    battery life is too poor so far. I got the phone recently and it automatically updated to Android pie. I don't use the phone that much , I get like about 2 or 3 hours or screen time. the worst part is that the battery keeps draining even when you don't use it. that's terrible. is there a way I can change back to the Android Oreo because I heard people say that the battery situation got this bad after the update. PLEASE HELP
    rakesh_sivva likes this.
  11. Silicon_Skeleton
    Gingerbread Dec 10, 2018
    Silicon_Skeleton , Dec 10, 2018 :
    Maybe it's due to your signal strength? If you don't use it as much then it should sustain itself fine unless something internally is keeping your phone activity high.
    Kytharsis likes this.
  12. Mukesh Rajan Nagarajan
    Mukesh Rajan Nagarajan , Dec 10, 2018 :
    Even I have the same problem... recently the battery drain has increased so much that I need to charge at least thrice a day. I tried to uninstalling so many apps. still doesn't help.
  13. sabbyjay
    sabbyjay , Dec 10, 2018 :
    The problem is there with most OnePlus 6 users after the 9.0 update.
    I have tried factory resetting, did not help.
    Removed apps which I thought could be the culprit, didn't help.
    The problem is the OS itself, not an app. And OnePlus is too busy updating the T model and working on the McLaren model to do anything about the OnePlus 6.
    Go figure.
  14. ArmataReloaded
    Jelly Bean Dec 10, 2018
    ArmataReloaded , Dec 10, 2018 :
    Nice theory, next time attach your app usage and your battery graph to have at least any evidence.
  15. z15364660126
    Froyo Dec 10, 2018
    ananyr and G_Vidur_Walia_oaGc like this.
  16. Shazo
    Froyo Dec 10, 2018
    Shazo , Dec 10, 2018 :
    if you have tried everything then give it a try to this
    turn off your phone
    hold vol down + power button together till display comes up.
    go into wipe and wipe cache. once done reboot and charge your phone for once till 100%. make sure to 100% .
    use your phone normally and avoid playing game.
    i did this and look at my stats. its even slightly better and yes i do play Vainglory on it.
  17. abhi8999
    Donut Dec 12, 2018
  18. erwinsavilla
    Cupcake Dec 12, 2018
  19. z15364660126
    Froyo Dec 12, 2018
  20. Tim_van_D
