3
Battery life of OnePlus 6
  1. Tim_van_D
    Cupcake Dec 12, 2018
  2. W1544428757666
    Cupcake Dec 24, 2018
    W1544428757666 , Dec 24, 2018 :
    what's wrong?!!!
  3. Silicon_Skeleton
    Gingerbread Dec 24, 2018
  4. G_Atin_Arvindo_WZBn
    G_Atin_Arvindo_WZBn , Dec 24, 2018 :
    My battery is pretty good, been using since I got it ( 25th May)
    didn't sense battery drain
    I was having lots of battery drain with PUBG, then I deleted it otherwise would screw up my battery.
    stop playing games on your phone and cry about battery drain, you're the one who is causing it all, not OP
  5. McNasty1304
    Donut Dec 24, 2018
    McNasty1304 , Dec 24, 2018 :
    I would recommend turning off the "Adaptive Battery" setting.
    I just got the 6t and noticed crazy drain on the battery and I was about to return the phone. then I saw somewhere else to turn that setting off and it has helped drastically.
    could possibly help some of you as well if you have that setting on the 6.
  6. W1544428757666
    but how can pubg drain the battery if you don't use it that often, and also if you have restricted background usage then it shouldn't be draining anything
  7. G_Atin_Arvindo_WZBn
    because of the graphics, uses a lot of more power, ram and cpu.
  8. W1544428757666
    that I understand but my phone's draining battery even when I'm not using it, like I'll keep my phone away while studying and when I take it back the battery percentage has decreased
  9. vidurwalia
    vidurwalia , Dec 24, 2018 :
    another possible reason for battery drain quickly is a virus, I learned it in a cyber security workshop that if your phone heats up and battery drains quickly try running antivirus or install apps like unhack me and make sure no malware is residing in the phone. I hope that's not the case and the service centre should help otherwise.
  10. G_Atin_Arvindo_WZBn
    try installing this app 3C battery monitor to check what's draining your battery and what's waking up your phone.
  11. Leon Smith
    Cupcake Mar 1, 2019
    Leon Smith , Mar 1, 2019 :
    I had the similar issue when upgrading to android P. My battery life was awful therefore I have rolled back to oreo! Now battery it as good as it was!
  12. Deactivated User
    Mar 1, 2019
