Battery Life on OP2
  1. CMHayes
    Gingerbread Sep 29, 2015
    CMHayes , Sep 29, 2015 :
    Morning everyone,
    So I was thrilled to receive my OP2 yesterday and am happy to report no major bugs.
    However, one thing I have noticed is the battery life does deplete rather quickly (I have lost 6% in the last 20 minutes!) I have already turned the screen brightness down, turned off location services, turned off the fingerprint scanner and made at sure Bluetooth is off.
    I have searched on the forums and a lot of people were suggesting rooting. I don't want to do this as I really don't know what I'm doing. Is there anything else I can do to improve battery life? Is it just a matter of it needing several charges to get going?
    I'd appreciate any advice people can give! :)
    Ashwith likes this.
  2. royz0r
    Jelly Bean Sep 29, 2015
  3. Sorin Zaharov
    Donut Sep 29, 2015
    Sorin Zaharov , Sep 29, 2015 :
    As I saw with my OP2, it needs some 1-2 cycles to calibrate. Besides that, I had some drain issues when the phone was in idle over night, it lots 35% in 8 hours. I restarted it and the viewed the battery usage with GSam. Turns out that I had a game running in the background :D.
    The restart "fixed" it. I now have about 3 hours of screen time and a total of 24 hours battery span.
    Hope this helps. Cheers!
    LE: I was on OxygenOS 2.0.3, recently upgraded to 2.1
  4. CMHayes
    Hi, I'm on 2.0.2 still waiting for OTA update. :(
    Ashwith likes this.
  5. keessonnema
    KitKat Sep 29, 2015
    keessonnema , Sep 29, 2015 :
    I'm having the exact same 'problem' will update my post after two or three cycles of charging. Otherwise I'll root and update manually with a clean install.
    CMHayes likes this.
  6. royz0r
    royz0r , Sep 29, 2015 :
    wait for the OTA it will improve battery life
    Ashwith, Artur Deus and CMHayes like this.
  7. CMHayes
    Thanks for the reply. My battery usage is showing Google Play services, screen and the OS as being the main drainers just now... I'm hoping it's just a matter of the battery calibrating as this won't even last a day at this rate!
    I'll try GSam and a restart and see if that works too.
  8. CMHayes
    I sure hope so. :)
  9. CMHayes
  10. pa5t1s
    User of the Year 2014 Sep 29, 2015
    pa5t1s , Sep 29, 2015 :
    I'm still on 2.0.2, not rooted, and here are a few screenshots of Battery Widget Reborn (sorry, in French, but self-explanatory imo...)
    Screenshot_2015-09-01-08-39-55.png Screenshot_2015-09-05-18-28-39.png Screenshot_2015-09-05-18-31-03.png Screenshot_2015-09-05-18-31-24.png
    Translation: 'j' for 'day', 'h' for 'hour' 'temps restant'='remaining time'
    CMHayes and nexus123 like this.
  11. Sorin Zaharov
    Donut Sep 29, 2015
    it's normal to indicate that screen on time and OS is draining your battery. it needs to record what other apps/services ar draining the battery so let it sit there and do your daily duties.
    cheers!
  12. nexus123
    SoniaB, CMHayes and pa5t1s like this.
  13. pa5t1s
  14. CMHayes
    No way? That's a lot better than mine. I've had a look on GSam and it appears that a ton of apps are running and all using 0.1% each.
    How do I manage this without breaking anything? I'm worried if I 'force stop' it might ruin something!
  15. nexus123
    nexus123 , Sep 29, 2015 :
    Thanks, I'm sure I would make a fool of myself.. You would have no problem identifying the redneck from Texas.. I'd be the one going........
    SoniaB and pa5t1s like this.
  16. pa5t1s
    Well, depends on which are the apps in your 'ton of' :(
    My OPT is not fully 'set up' with all my apps yet, but I have a decent and average '2 days without charging' , depending on my use ofc.
  17. pa5t1s
    Cool:) you'll probably enjoy your stay in South of France, in 'Camargue'. Never been in Texas so far, but that should be a right place for 'redneck': wide areas, cows and bulls, corridas... Google that ;)
    nexus123 likes this.
  18. pa5t1s
  19. CMHayes
    No way? That's crazy!! I have the apps I used on my Nexus 6 on here so I may well get rid of some of them to be honest. However, here is what GSam is showing so far after I installed it this morning (see screenshots).
    I had no idea as many apps were running!
  20. nexus123
    pa5t1s, CMHayes and SoniaB like this.
