2
Battery life on the one plus two?
  1. OathWing
    Honeycomb Aug 25, 2015
    OathWing , Aug 25, 2015 :
    I am a heavy user when it comes to phones. I play games whenever I get the chance and I was wondering how is the battery life?
    TiramisuNY and zinokad like this.
  2. dursuntosun
    Donut Aug 25, 2015
  3. punith00070
    Eclair Aug 25, 2015
    punith00070 , Aug 25, 2015 :
    if u have LTE turned on., it drains oneplus 2 battery like anything. but if switch to 3 G, u get pretty decent battery life. With moderate usage with 3g enabled all the time., i can pull off a day.. (After update)
    TiramisuNY likes this.
  4. psindh
    Cupcake Aug 25, 2015
    psindh , Aug 25, 2015 :
    i am also scared about the battery life but i think i'll be worth a risk
  5. punith00070
    Eclair Aug 25, 2015
    yeah hopefully it gets better with next updates. except battery backup., everything is awesome in this phone. I come from lenovo p780 which had massive 4000 mah battery. so i find this battery life very short.
  6. EXAWOLT
    EXAWOLT , Aug 25, 2015 :
    If you keep good care for it, it should be very fine.
    Here are some tips from me how I keep my battery healthy.
    1 Don't install shit like Facebook App.
    2 On and off, restore your phone to factory settings completely.
    3 Power off the phone when you can. Closing the system and spare the battery some constant process keeps it healthy.
    4 Use manual settings and disable 3g/4g, wifi, location, gps, sync, when not in use.
    5 Use fast setting to lower the screen brightness when you don't need it.
    6 Clear the RAM processes as often as possible.
    7 Enter special settings on CPU processor, and give it maximum 1.6ghz, you won't need more.
    8 Check if your battery is damaged;
    Enter this code through CALL: *#*#4636#*#* (Don't do anything stupid here!)
    Now you can see your phone temperature, and battery health and so on.
    If it's not good, power off the phone more often, or get it replaced.
  7. amruthamba fnu
    Gingerbread Aug 25, 2015
    amruthamba fnu , Aug 25, 2015 :
    Before upgrade, battery life wasnt as good as OPO. Not sure what's up after the update.
  8. punith00070
    Eclair Aug 25, 2015
    Wats the point of buying this phone if you don't use its power :)
    OathWing likes this.
  9. anjan2683
    anjan2683 , Aug 25, 2015 :
    You know that the first thing that someone would do is install Facebook, right?
    rguarascia and EXAWOLT like this.
  10. EXAWOLT
    It's more power than you'll need ;)
  11. kc4one
    Ice Cream Sandwich Aug 25, 2015
  12. OathWing
    i am too don't worry you're not alone
  13. OathWing
    Like i said i'm a heavy user.
  14. OathWing
    EXAWOLT likes this.
  15. kc4one
    kc4one , Aug 25, 2015 :
    Happy to know that
  16. OathWing
    from reviews they said that they put it to the limits and said that the battery was amazing.
  17. fazerboy0_3
    Honeycomb Sep 19, 2015
  18. mohitpatle
    Cupcake Sep 22, 2015
    mohitpatle , Sep 22, 2015 :
    I've recently bought OnePlus Two and do not have too much of 4G or 3G usage..... Even after that battery drains very fast...... Not sure whether it was a right discussion from my side. Pls confirm if you experience similar.
  19. pioupiou1211
    Gingerbread Sep 22, 2015
    pioupiou1211 , Sep 22, 2015 :
    My best is 6h of sot. But i don't use the phone a lot in week because i'm at school. So in week, it's 3h of sot and 2 days of idle. Good battery life
  20. Hashss
    Hashss , Sep 22, 2015 :
    Good
