Battery life via OnePlus 7 Pro
  1. #1
  2. SRD.
    Lollipop Apr 17, 2021
    J4t1np4r3kh likes this.
  3. #3
  4. #4
  5. jontalk
    Ice Cream Sandwich Apr 17, 2021
    jontalk , Apr 17, 2021 :
    Without doubt this is one of the most common issues after an update and 99.9% of the time its related to apps rather than the update. The more third party apps you have installed, the more likely they're the reason..I'd suggest you disable or remove some of them and see if it improves. It also can take several days for the update to acclimate :)
    the_o2 and Artemus. like this.
  6. #6
    the_o2 likes this.
