Battery life
  1. gerardvanschip
    Honeycomb Jun 11, 2018
    gerardvanschip , Jun 11, 2018 :
    I see so many posts about battery life. On my 3T I would burn through a solid 20 to 25% of my battery on my long journey into work. On my 6 I stay under 15%.
    Anyone else noticing better battery life? BTW running regular android, not the very early P beta.
  2. Prcko
    KitKat Jun 11, 2018
    Prcko , Jun 11, 2018 :
    compare durability 3T and 6 is how to compare your car and sports car. it can not be as long as 3T. 6 has a larger display of other hardware so it can not be compared directly and it's not even right.
  3. elanglois
    Lollipop Jun 11, 2018
    elanglois , Jun 11, 2018 :
    Totally wrong.
    Display size means nothing. It has a minor percentage more transistors in the display, but the newer technology can mean MUCH less power to activate the transistor and lower current draws total. The CPU itself is a prime example. It's faster with more transistors, yet uses less power than a 3T for the same amount of work.
    W1526719914186 likes this.
  4. Prcko
    KitKat Jun 11, 2018
    with something you agree is right. but take into account that 3T has a smaller display resolution than other hardware and a stronger battery, which is reflected in the percentage of battery status indicators. so it can not be compared directly.
  5. G_Avee_B_Xaxb
    Jelly Bean Jun 11, 2018
    G_Avee_B_Xaxb , Jun 11, 2018 :
    you're right base on theory, but on actual experience my 3T last longer than my 6
  6. elanglois
    Then you did something really wrong. Find what is wrong with your OP6 and fix it. Or maybe Oneplus botched the OS
  7. Prcko
    KitKat Jun 11, 2018
    every time I hear how the new processor is faster and more energy efficient. each time they put the same or stronger battery on the new phone, and the result is that the older model had better stamina. just compare the Samsung Galaxy s8 and s9. better processor unchanged automatically better stamina. of course, it has its role to optimize and in the case of oneplus 6 we still have to wait. oneplus 3T has gone through several updates so we can talk about better optimization
  8. gerardvanschip
    Honeycomb Jun 12, 2018
    gerardvanschip , Jun 12, 2018 :
    I'm confused. I'm writing that my 6 has a MUCH better battery life. Why are people. Talking about me having to wait for optimisation? Is it going to get even more amazing?
  9. Prcko
    KitKat Jun 12, 2018
    Prcko , Jun 12, 2018 :
    Hello. I wrote that it is difficult to compare the consumption of two different phones based on the battery indicator. that the debate has changed to unrecognition is common is the debate. in my view, the percentages are important. it's me to keep my phone all day long.
  10. rubencdl
    Froyo Jun 12, 2018
    rubencdl , Jun 12, 2018 :
    How many hours of active display do you have at the end of a full charge cycle?
  11. V1528787446134
    Cupcake Jun 12, 2018
  12. panchodiaz
    Eclair Jun 12, 2018
    panchodiaz , Jun 12, 2018 :
    why you dont post your battery status screenshot as soon as you reach 15% . Thus you can show us the phone usage during the day.
