11
Battery on my OP3 is dying since Last Updates
  1. G_Praveen_Sharma_QJyW
    Cupcake Apr 20, 2017
    #41
    Trilochan@86 likes this.
  2. G_Billybob_Schneider_lnm
    Froyo Apr 20, 2017
    G_Billybob_Schneider_lnm , Apr 20, 2017 :
    Ok thanks, I just need to backup everything somehow. What way do you recommend to do it?
    #42
  3. _DEDSEC_
    Jelly Bean Apr 20, 2017
    _DEDSEC_ , Apr 20, 2017 :
    ES file explorer for Apps back up, and something like Super back for Chat Messages, SMS Message, And browser Book marks. Make sure you know what you are backing up before formatting. I don't need to those backup so I just back up my apps and format it. Only application and application data will be deleted during factory reset.
    #43
  4. Harsh Agrawal
    #44
  5. G_Billybob_Schneider_lnm
    Froyo Apr 20, 2017
    I meant for factory reset
    #45
  6. _DEDSEC_
    Yep, I meant it for that.
    #46
  7. emekauwanekezi
  8. jim262
    Ice Cream Sandwich Apr 20, 2017
    jim262 , Apr 20, 2017 :
    I have many, many times. All you need to do is search this site, as well as the entire internet. That is what I did. Go look for it, I would bet you have never even tried, as there are tons of videos, tutorials and other posts/articles available on this subject.
    #48
  9. G_Billybob_Schneider_lnm
    Froyo Apr 21, 2017
    #49
    _DEDSEC_ likes this.
  10. G_Billybob_Schneider_lnm
    Froyo Apr 22, 2017
    G_Billybob_Schneider_lnm , Apr 22, 2017 :
    by the way, is there any good guide or forum on YouTube or this forum to do the factory reset backup and everything?
    #50
  11. Vikram Maniram Gautam
    Cupcake Apr 22, 2017
    #51
  12. G_Nilanjan_De_LMjQ
    G_Nilanjan_De_LMjQ , Apr 22, 2017 :
    anyone having problem with Skype..
    I find that Skype is draining my battery.
    was on Skype video call for like 1.45 hrs and Skype ate up 40%+ of my phone juice. also it heated my phone up too.. minimal..but still warmed
    #52
  13. apurv93
    apurv93 , Apr 22, 2017 :
    gone through the thread...done all the tasks..still battery is draining..I think its an OS update issue
    #53
  14. _DEDSEC_
    Jelly Bean Apr 22, 2017
    _DEDSEC_ , Apr 22, 2017 :
    Nope
    #54
  15. _DEDSEC_
    You can check my post though, "Why it's a good idea to format your OP3"
    #55
  16. _DEDSEC_
    Hey, I just formated my device, had a lot of glitches running around, and now my camera bug is fixed, my device is lag free, battery issues are also fixed, and I have all my data (even call logs). So I thought you might find it helpful.
    Download Super Back Up from play store
    Back Up everything that is listed
    Then connect your device to a computer
    Copy the following folders to desktop: Android, Bluetooth, DCIM, Music, Documents, Download, Movies, and the folder that you chose to store all your backup using Super Back Up.
    Then go to back up and reset, chose erase internal storage, once formated, finish the set up and copy all the folders from your PC, overwrite the folders in you Phone and your done, install Super Back Up again and select restore from each individual section. Make sure you have pasted in the exact same place you copied from.
    #56
  17. G_Billybob_Schneider_lnm
    Froyo Apr 22, 2017
    I'll probably do a factory reset first, but if it doesn't work, I'll do that.
    #57
  18. G_Billybob_Schneider_lnm
    Froyo Apr 22, 2017
    #58
  19. _DEDSEC_
    Jelly Bean Apr 23, 2017
    #59
  20. G_Billybob_Schneider_lnm
    Froyo Apr 23, 2017
    #60
