battery oneplus 6 + backcover
  1. Daan_Deurloo
    Cupcake Feb 15, 2020
    Daan_Deurloo , Feb 15, 2020 :
    i have replaced the battery on nu OP6 today and thought the back cover was made from aluminium. Welk that's not the case. It cracked when removing, it was heated and used tools made for phones.
    Next thing: how long usually the battery lasts for till it needs to be replaced? battery didn't last long ( 20% if lucky at end of the day and accu battery said 2700-2750 mah ).
    Used to be 60% at end of day.
  2. Kytharsis
    Nougat Feb 15, 2020
    Kytharsis , Feb 15, 2020 :
    Back cover is made from tempered glass, the frame/rails are aluminum. Replacing the battery won't fix the drainage issue.
    Caomhin, drl431 and Daan_Deurloo like this.
  3. Daan_Deurloo
    Kytharsis
    Will see if there is differance by time.
    Battery was not that expensive ( original oneplus ).
    Replaced the charging port while at it. microphone board is coming next week as one of the wifi connectors snapped.
  4. Kytharsis
    Nougat Feb 15, 2020
    Good luck.
    Daan_Deurloo likes this.
  5. Daan_Deurloo
    Cupcake Feb 16, 2020
  6. Daan_Deurloo
    Cupcake Feb 24, 2020
    Daan_Deurloo , Feb 24, 2020 :
    i have changed out the battery again as the new one was acting up and die around 20%. clearly a bad batch.
    Sending item back for RMA if the old one does fine.
    Just in case if it will explode later.
