9
[Submitted] Battery Optimization settings are reset for some apps
  1. perqin
    Donut Feb 2, 2018
    perqin , Feb 2, 2018 :
    Set the Battery Optimization to "Not Optimize" for some apps and wait for about one day
  2. megajules
    Cupcake Apr 2, 2018
    megajules , Apr 2, 2018 :
    This is happening to me as well. I have a OnePlus 3, running OxygenOS 5.0.1.
    Apps which have their Battery Optimisation set to "Don't Optimise" get changed back to "Optimise". I mainly use "Don't Optmise" for email clients (Inbox, BlueMail), and when this happens, i no longer received notifications.
    The setting seems to survive a reboot, and an app update. Unsure how this gets reset.
    PSSF23 likes this.
  3. PSSF23
    Gingerbread May 11, 2018
    PSSF23 , May 11, 2018 :
    Similar issue here. OnePlus 5T on Open Beta 7. My app of problem is Inbox by Gmail. I think this issue may have something with the advanced optimization settings, so could you please tell me whether you turned on Advanced Optimization?
  4. megajules
    Cupcake May 11, 2018
    megajules , May 11, 2018 :
    Hi PSSF23
    Yes, by default i believe advanced battery optimisation comes turned on on my OnePlus3, so all my apps have been set to Optimise. I manually set apps to Don't Optimise, to ensure notifications are displayed. And a few days ago, my "Don't Optimise" settings got cleared, so i had to re-apply them again.
    Maybe until this is fixed, I could always disable advanced battery optimisations. I'm not sure how much extra battery life i gain. Normally at work I'm constantly charging my phone anyway.
  5. Robson_DeluXeXBR
    Eclair Jul 5, 2018
    Robson_DeluXeXBR , Jul 5, 2018 :
    Same here. The app Strava are getting optimized always even I set it to don't optimize. Any solutions?
  6. megajules
    Cupcake Jul 7, 2018
    megajules , Jul 7, 2018 :
    I haven't had this problem for a while now. I have upgraded my OnePlus3 to Oxygen 5.0.3, so it may have been fixed in that build? (it wasn't mentioned in the change log)
    Edit: i spoke too soon. i still have this problem :(
  7. PSSF23
    Gingerbread Jul 9, 2018
    PSSF23 , Jul 9, 2018 :
    I tried turning off advanced battery optimization, but that didn't solve this problem. My settings were still resetted. So the problem should be about the system, maybe Android Oreo in general.
    megajules likes this.
  8. aspiers
    Cupcake Aug 7, 2018
  9. DenyDarko
    Honeycomb Aug 8, 2018
  10. johnmon
    Cupcake Aug 30, 2018
    johnmon , Aug 30, 2018 :
    It's happening to me! It's awful, apps stop working entirely because of this issue. I'd rather turn off the optimization altogether than deal with going through a list of every app and find which ones decided to reset their options just to be able to use my phone without constant issues...
  11. G_Энди_Савин_Ak
    Gingerbread Aug 31, 2018
