Battery/Charging Battery Percentage stuck ,
  1. MouhamadBzou
    Donut Jan 8, 2017
    MouhamadBzou , Jan 8, 2017 :
    Hello ,
    I had this issue two days back (on the old build before updating to 3.5.6, I don't remember the build number but it was the latest official update)
    The battery was stuck at 100% for long time after unplugging the phone from the charger, I managed the drain the battery till the phone switched off, then charging again,
    next day i receive the 3.5.6 OTA update which I did,.
    today the battery was stuck at 83%(more than 5 hours now),. looks like the battery was not fully charged at night (maybe very sow charging time as some say)
    any idea what is the solution of the battery stuck, ?
    Thank you
    F_Luiz_Domingues_zjUX likes this.
  2. dipta.ds
    Honeycomb Jan 8, 2017
    dipta.ds , Jan 8, 2017 :
    Did you notice a sudden drop in the battery percentage after it was stuck at the same value?
  3. pratiush29
    Gingerbread Jan 8, 2017
    pratiush29 , Jan 8, 2017 :
    it seems your phone is giving you the best backup ever!! that's cool man why complain [e]1f609[/e]
    airiartev likes this.
  4. MouhamadBzou
    Donut Jan 8, 2017
    yes in both occasion ,
  5. MouhamadBzou
    Donut Jan 8, 2017
    Lol, I should spend it wisely then ,.
  6. dipta.ds
    It's a problem with the battery calibration then. Calibrate it and it should be fine
  7. MouhamadBzou
    Donut Jan 8, 2017
    I believe by using an app right ?
    any app recommendation ?
    Thank you
  8. Zaheer Maniyar
    Eclair Jan 8, 2017
    Zaheer Maniyar , Jan 8, 2017 :
    Sir Keep your phon connected with charging cable and then try *#808# code then after screen will be displayed like as bellow and go to the charging option and wait for 30 seconds.
    Then if it show you pass message in green text as shows below, it means your charger and cable is working properly if it not show you a this paas Message then there's a problem with your charger socket or may b with a cable. So you have to change a cable or socket from your near by oneplus service center.
    virendra1967 likes this.
  9. MouhamadBzou
    Donut Jan 8, 2017
    I've just downloaded Advanced battery calibrator,
    I will do the calibrating at home as it requires charging the battery to 100% right after calibration
    Will update the post , many thanks
  10. MouhamadBzou
    Donut Jan 8, 2017
    I will also test this at home , as I dont have proper cable at work now,
    Thanks a lot
  11. samuelchan727
    samuelchan727 , Jan 8, 2017 :
    I have same issue today, just clear cache form recovery then the battery percentage will return to normal and drain battery as usual.
  12. pratik1008
    Cupcake Jan 8, 2017
    pratik1008 , Jan 8, 2017 :
    Was facing same issue. Changed the charger cable. Now no issues related to charging.
  13. gagan.singh
    Donut Jan 8, 2017
  14. Kiran Kumar Malemarpuram
    Cupcake Jan 9, 2017
  15. endosan
    Cupcake Jan 9, 2017
  16. animezzzzz
    Cupcake Jan 9, 2017
  17. MouhamadBzou
    Donut Jan 9, 2017
    MouhamadBzou , Jan 9, 2017 :
    The calibration does not seem to work I tried couple of highly rated apps , It did not work
  18. MouhamadBzou
    Donut Jan 9, 2017
    Do you mean factory reset from recovery ?
  19. gelopots
    Cupcake May 22, 2018
    gelopots , May 22, 2018 :
    Hi, this app worked for me! Battery meter was stuck at 50% but after installing this app, calibrating, shutting off the phone, then fully charging it, it is now back to normal.
  20. gelopots
    Hi, on my device, it does not show PASS or FAIL. How long do I have to run this test?
