battery performance
  1. X1519324120322
    Cupcake Nov 8, 2018
    X1519324120322 , Nov 8, 2018 :
    hi,
    recently my battery performance has reduced really low
    from day one it was really good but just like past 3 days my battery is very very poor. please do let me know any remedy for it.
  2. stark2991_PL
    KitKat Nov 9, 2018
    stark2991_PL , Nov 9, 2018 :
    You have to show your battery stats first.
  3. Ashishkumar02
    Eclair Nov 9, 2018
  4. stark2991_PL
    KitKat Nov 9, 2018
    Dude, use your phone normally till you get 10-20%, and then post your battery stats with app usage
  5. Ashishkumar02
    Eclair Nov 9, 2018
  6. X1519324120322
    Cupcake Nov 9, 2018
  7. cedric88350
    Froyo Nov 9, 2018
  8. X1519324120322
    Cupcake Nov 9, 2018
  9. X1519324120322
    Cupcake Nov 9, 2018
  10. cedric88350
    Froyo Nov 9, 2018
    cedric88350 , Nov 9, 2018 :
    Redémarrez le téléphone en mode récupération.
    Éteindre le smartphone.
    Redémarrer en volume sur moins.
    Aller sur anglais
    Et sur cache et faite wipe cache
    Chercher sur le forum c est indiqué
  11. X1519324120322
    Cupcake Nov 9, 2018
  12. cedric88350
    Froyo Nov 9, 2018
  13. I1541760016161
    Cupcake Nov 9, 2018
    I1541760016161 , Nov 9, 2018 :
    from Google translate: Restart the phone in recovery mode.
    Turn off the smartphone.
    Restart in volume on less.
    Go to English
    And on cache and made wipe cache
    Search the forum c is indicated
  14. cedric88350
    Froyo Nov 9, 2018
    Tu fais ton effacement cache et normalement tu verras la différence dans les prochains jours
  15. X1519324120322
    Cupcake Nov 9, 2018
  16. Edgar Palau
    Froyo Nov 9, 2018
    Edgar Palau , Nov 9, 2018 :
    I had exactly the same, it seems to me that it was some kind of ongoing wrong update.
  17. cedric88350
    Froyo Nov 9, 2018
    Normalement, c'est l'écran qui doit être en tete de liste.
    Le système Android doit être en 2%et 12% maximum
  18. cedric88350
    Froyo Nov 9, 2018
  19. N1513510080942
    Eclair Nov 10, 2018
  20. Ashishkumar02
    Eclair Nov 10, 2018
    Ashishkumar02 , Nov 10, 2018 :
    same with me there is only solution that really work having a factory reset without copy your old data
