Battery replaced
  1. Jordi1880
    Froyo Apr 29, 2017
    Jordi1880 , Apr 29, 2017 :
    hi guys and galls, I'm still on the Oneplus One, I've had this for over two years, which is by far the longest I've ever had a phone. The last 6 months the battery showed signs of giving out, to the point that I had to constantly carry around an external battery when I wasn't at home or at my office. A few days ago I succesfully replaced the battery and the microphone (broken), with parts I ordered from eBay and **********. This hasn't improved battery life so now I'm looking for other reasons for my bad battery. Are there any other technical parts that might be faulty and which I can replace myself? Or should I look to the software side of things? I'm on stock android 5.0.2 and Oxygen 1.0.3, I'm not running any custom launchers etc, and I j don't have anything special running. Any advice?
    G_Himanshu_Seth_pyPb likes this.
  2. pa5t1s
    User of the Year 2014 Apr 29, 2017
    pa5t1s , Apr 29, 2017 :
    If your battery is older than a week and at least 2-3 charge/discharge cycles, and if you can't see improvements, yes, the problem is not with the battery :)
    Or the battery you bought is not a genuine one (? I guess that the ***** mean AliE, right?)
    Have you any clue about which apps are using it a lot?
    Advice: switch to LineageOS?
  3. elanglois
    Lollipop Apr 29, 2017
    pa5t1s and ajay968968 like this.
  4. G_Dark_Side_pqvZ
    Donut Apr 29, 2017
    pa5t1s likes this.
  5. fatfingers
    Honeycomb Apr 29, 2017
    fatfingers , Apr 29, 2017 :
    Did you check the date on your new battery?
    Amazon and eBay batteries seem to be dated 2015.
    https://www.amazon.com/Original-Replacement-Battery-BLP571-3100mAh/dp/B010Q234AO
    http://www.ebay.com/itm/New-Origina...dc7e76&pid=100677&rk=2&rkt=42&sd=282216595433
  6. Mykson
    Ice Cream Sandwich Apr 29, 2017
    Mykson , Apr 29, 2017 :
    The software goes hand in hand with the hardware.
    As @pa5t1s said, switch to LineageOS (or Resurrection Remix) which is now at Android 7.1.2.
    I also have my One over 2 years now and there aren't any battery problems, battery lasts around 24 hours with ~4 hours SOT at normal use. Check my signature.
    Franjo and pa5t1s like this.
  7. Franjo
    Jelly Bean Apr 30, 2017
    Franjo , Apr 30, 2017 :
    I'm on RR and battery is great for almost 3y old phone. 3,5-4h sot.
    Mykson likes this.
  8. F_Pankaj_Aggarwal_SMCr
    Cupcake Apr 30, 2017
