Battery Replacement
  1. I1518526797281 Cupcake Feb 13, 2018
    I1518526797281, Feb 13, 2018 :
    Guys I need to replace my OP3 battery but I'm in UAE is there any store to replace my battery in UAE?
  2. NeVeR_SeTTLe The Lab - OnePlus 6 Reviewer Feb 13, 2018
    idkwhoiam322 and I1518526797281 like this.
  3. I1518526797281 Cupcake Feb 13, 2018
  4. NeVeR_SeTTLe The Lab - OnePlus 6 Reviewer Feb 13, 2018
    NeVeR_SeTTLe, Feb 13, 2018 :
    Do they deliver to the UAE, just out of curiosity?
  5. U1518159509487 Cupcake Feb 13, 2018
    U1518159509487, Feb 13, 2018 :
    it is taking around 90-110 minute to take in full charge of mobile...where as it should be fast charging , i.e. in 60 mnte only...??
  6. NeVeR_SeTTLe The Lab - OnePlus 6 Reviewer Feb 13, 2018
    Your charging port might be damaged or there might be some dust that got accumulated. Another reason might be your cable might be damaged. First try to blow out with air your charging port. If that doesn't help, try to see on another dash charging cable if you are getting the required speeds.
  7. I1518526797281 Cupcake Feb 13, 2018
  8. NeVeR_SeTTLe The Lab - OnePlus 6 Reviewer Feb 13, 2018
    Don't you have in UAE something similar to EBay or Amazon? You could try Aliexpres
    idkwhoiam322 likes this.
  9. I1518526797281 Cupcake Feb 13, 2018
    ********** will be full of fake non genuine products, we have Amazon store derived from Souq.com and Oneplus store in it but only sell the phones and some accessories that isn't including batteries
  10. NeVeR_SeTTLe The Lab - OnePlus 6 Reviewer Feb 13, 2018
    Then sorry to say, but your out of luck :(
  11. NeVeR_SeTTLe The Lab - OnePlus 6 Reviewer Feb 13, 2018
    Why don't you send it to OnePlus for replacement?
  12. I1518526797281 Cupcake Feb 13, 2018
    [e]1f602[/e][e]1f602[/e][e]1f602[/e][e]1f602[/e] thank u anyways buddy, I'll manage to get it from the US
  13. NeVeR_SeTTLe The Lab - OnePlus 6 Reviewer Feb 13, 2018
    Sorry I couldn't be any of more help.
  14. I1518526797281 Cupcake Feb 13, 2018
    No I really want to thank you for even replying that was great from u, thank u bro
  15. G_plusone Lollipop Feb 13, 2018
    G_plusone, Feb 13, 2018 :
    It will take around 80 to 90 minutes from 0 to 100.
    Tried clearing the charging ports on the phone and the charger? , they are fragile so be carefull
