Battery saver bug
  1. VirajTr
    Cupcake May 22, 2019
    VirajTr , May 22, 2019 :
    When the battery goes down and the battery saver mode is detected, if doesn't get turned off automatically once you charge the phone back.
    On charging, the phone goes above the battery saver on range but still as soon as you unplug the phone, the battery saver continues to stay on.
  2. DVNK09
    Gingerbread May 22, 2019
    DVNK09 , May 22, 2019 :
    I had a little bit of a hard time understanding the description. It soubds like battery saver is just not going off.
    So first, make sure you do not have a certain percentage that battery saver starts at a high number. Also try clearing cache or resetting the phone. I do not know what you have done to stabilize this issue so I am giving advice.
  3. VirajTr
    Cupcake May 26, 2019
    VirajTr , May 26, 2019 :
    So the thing is - battery saver is set at below 15%. Now when the charge goes below 15% it gets on. But after that, when I put the phone on charge and say, I charge it to 85%, on unplugging the charger, the battery saver doesn't turn off automatically even though the charge is 85%.
  4. DVNK09
    Gingerbread May 26, 2019
    DVNK09 , May 26, 2019 :
    Okay I understand now. So I have not heard of this issue before but I would just disable battery saver and restart, then re-enable it. Clear cache on the phone maybe and see.
  5. VirajTr
    I already did that, but still all the same. Unable to get the issue resolved.
  6. DVNK09
    I haven't seen an issue before, you may need to factory reset.
  7. osheen29
    Cupcake Aug 20, 2019
  8. Shashikiran_Neelakantaiah
    Eclair Aug 27, 2019
    Shashikiran_Neelakantaiah , Aug 27, 2019 :
    Yes, Oneplus does not automatically off the Battery Saver option once it is turned ON, it has to be turned off manually. This maybe a forgotten feature from the OnePlus or it is left for the user consent as to when to ON and OFF the Battery Saver feature.
  9. Q1538325785599
    Cupcake Oct 18, 2019
    Q1538325785599 , Oct 18, 2019 :
    I have the same issue.
    when I plug my mobile for charge and remove... it goes to battery saver mode ☹️
