battery saver
  1. G_Vinayak_Sp_Ainp
    Froyo May 31, 2018
    G_Amarnath_Sonth_esgg likes this.
  2. Kytharsis
    Marshmallow May 31, 2018
    Kytharsis , May 31, 2018 :
    When it's used properly, sure. Why, is your battery draining too quickly?
  3. G_Vinayak_Sp_Ainp
    Froyo May 31, 2018
    G_Vinayak_Sp_Ainp , May 31, 2018 :
    not draining quickly. but I found no difference between the battery drain wen battery saver on and off
    Jawe1212, Waquar222 and nerveaxis like this.
  4. Kytharsis
    That's because it's meant to be used when the phone's close to dead. It slows down the CPU and hinders some features to conserve as much battery as possible. It's useless while there's enough life to last the day.
    Poul_Werner_Dam likes this.
  5. serafica.josh
    Eclair Jun 18, 2018
    serafica.josh , Jun 18, 2018 :
    so battery saver has no effect when battery is high?
  6. Kytharsis
    Marshmallow Jun 18, 2018
    Kytharsis , Jun 18, 2018 :
    Nope. All that does is slow down the CPU/GPU to conserve power. That's why there's an option to turn it on automatically when it's at low battery.
  7. serafica.josh
    Eclair Jun 18, 2018
    I wonder if there's a time study done to see how much time is consumed when using batter saver right after charging
  8. Kytharsis
    Dunno, maybe. Usually that's what it does though.
  9. G_Vinayak_Sp_Ainp
    Froyo Jun 27, 2018
    G_Vinayak_Sp_Ainp , Jun 27, 2018 :
    as battery saver turns on automatically after going below15%. the battery draining speed LL be same as before saver is turned on.. no use of battery user. infact it doesnt do it's work
  10. kermex
    Honeycomb Jun 27, 2018
    kermex , Jun 27, 2018 :
    The best battery saver is the one which stand in front of the phone :grin:
    Budruel, Majuran thas and Dresa91 like this.
  11. serafica.josh
    Eclair Jun 27, 2018
    serafica.josh , Jun 27, 2018 :
    I beg to disagree. I tried turning on the battery saver right after charging and compare the SOT with off battery saver and tried fully using the phone the same amount of time. Really not going bias here. I might say there's a difference between SOTs. Well, if you're saying turning on the battery saver at 15%, well I can say that there's not much significant difference
    G_Vinayak_Sp_Ainp likes this.
  12. G_Vinayak_Sp_Ainp
    Froyo Jun 27, 2018
    yea. I just wanted to say. we need a significant difference. that's all
  13. Khattak1122
    Eclair Jun 27, 2018
  14. serafica.josh
    Eclair Jun 27, 2018
    Significant difference like for example 15% with battery saver off lasts around 2 hours vs 15% with battery saver on lasts around 4 hours?
  15. G_Vinayak_Sp_Ainp
    Froyo Jun 28, 2018
    G_Vinayak_Sp_Ainp , Jun 28, 2018 :
    seriously? ooooo pls
  16. serafica.josh
    Eclair Jun 28, 2018
  17. Deactivated User
    Jun 28, 2018
    Josefine_Paaske likes this.
  18. Josefine_Paaske
    Cupcake Aug 21, 2018
  19. Josefine_Paaske
    Josefine_Paaske , Aug 21, 2018 :
    what does gaming mode do to the battery?
  20. aybouzaglou1
    Eclair Aug 21, 2018
